Question about Palm Tungsten E Handheld
Calibrating the stick and screen
I have just re-activate my palm after 2 years and I missed the part about calibrating the screen.When I touch the screen with the stick, it doesn't work unless I am a bit offset of the icon/button.I know there is a calibrating mode with small targets to be touched but I cant find how to go to this application, even when I reset the palm.ThanksFred
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Go into system and choose calibration.
Posted on Dec 30, 2008
Palm tx -touch screen is not working
try screen calibration you can find it in prefs. if not solved, try installing powerdigi. it calibrates screen almost perfectly!
source: my experience!
Sep 06, 2010 | Palm TX Handheld
P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Jun 17, 2009 | Sony Ericsson P990i Cellular Phone
My TX's Top Left quadrant of the touch screen has lost "sensitivity" but generally the whole screen is out of calibration.
have you tried using the built in calibration function on your phone? calibrate it again and again untill you can touch each point just once. if this doesnt work you may have damaged that part of the digitizer and you will have to replace the screen.
Jun 12, 2009 | Palm TX Handheld
Palm m515 When I use the stylist it will not work where I push I reset and it still did not work
you need to recalibrate the touch screen ..
touch the "Home" button a few times until you get "system" in the top right corner .. then select "Welcome" .. that will let you calibrate the touch screen and set the clock/calendar ..
Apr 24, 2009 | Palm m515 Handheld
Palm Tungsten E/E2 digitizer - fragile?
Palm one is in trouble because of problems like this. They don't work on it but you can buy parts to try it yourself. I never had the problem myself but similar conditions. I do windows based units now.
Dec 30, 2008 | Palm Tungsten E2 Handheld
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
Screen problem
Sometimes 3rd party apps that don't work so well with the palms can freeze them up.
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=2,E=0000000000825403011,K=4996,Sxi=18,Case=Obj(26419)
You could do a hard reset and when you initially sync the palm, when it asks you for a profile choose a new one and see if this method removes your problem.
Diagnosing problems by 3rd parties link- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908)
More info-
Does the calibrator keep looping or not seem to work?
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
  • Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
  • You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
  • A heavy impact or scrape to the touchscreen can cause permanent damage. If your touchscreen is damaged, you may need a repair
Jan 08, 2008 | HP iPAQ RX3715 Pocket PC
Touch Screen does not work at all
My touchscreen was acting batty, not responding where I was touching. The solution for me was to:
1. remove my screen protector
2. Take a piece of paper, fold it in half, and scoop under the lip the case where it holds the touchscreen in to fish out debris that were distorting how the digitizer recorded.
Nov 14, 2007 | Palm TX Handheld
Touchscreen no longer works
Well watch this video and after you follow the directions get the screen and find the glass like cover and remove it from the screen bend it in a very lightly way, then put it back on and put the PDA back together and BAM.
Nov 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E Handheld Logo
231 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
