Question about Samsung HLP4663W 46" Rear Projection HDTV
My Samsung 61' TV will not show the menu\source in order to change the source from SVideo to TV
  • 98 Answers
Need to replace the main board.
Posted on Feb 11, 2009
Samsung TV (Model Number: UN55ES6550F) has sound, but no longer has video
i don't know. there is a possibility the on screen menue has been changed to another input 'source' if your TV
has that feature. mine shows a list to choose from.
eg. TV, hdmi i, 2 &3 , AV, cable, air. hope you can see
MENUE on your video by using either your remote or
the physical buttons on yout TV.
May 04, 2018 | Samsung Televison & Video
I am trying to connect my laptop, the option for PC is not highlighted, therefore I cannot use it as an input source. Is there a way I can change the input source menu?
no you cant change the input source menu
source must be present and active for it to show in menu
make sure PC is hooked up to VGA input and make sure PC is toggled so it has the display going to TV - once this is correct you should see it as an input option
write back if you need more help and give m,e more details like what type of PC you are hooking up as well as what input and wiring you are trying
good luck!!!
Mar 29, 2011 | Samsung LN40A550 LCD TV
How do i set componet 2 to hdtv on a samsung HLN617W, it says unsuppoted mode
When you get an Unsupported mode error on this tv, its usually not the tv. Change the resolution on the source to something the tv can handle.
Sometimes samsung labels the component ports in the back of the set so you know what it can accept.
Dec 05, 2009 | Samsung HLN617W 61" Rear Projection HDTV
How do i get better picture quality
It all depends on your signal source (ie. cable antenna or satellite) if available from your signal source the first choice is 1- HDMI -2 DVI -
3 Component video (RGB)- 4 Svideo - 5 composite video (yellow RCA) and finally through channel 3 in that order othewise digital tuner in.
Oct 02, 2009 | Samsung LE37R72B 37 in. HD-Ready LCD...
Gray box on screen with sound.
It sounds like you need to turn off the text mode in the closed captioning menu,
Jul 23, 2009 | Samsung HLT6187SAX 61" DLP HDTV
I have a 61 inch Samsung DLP. Works great except
it is configurable in the menu options. if you change there and goes back to how it was then you are probly in shop mode.
Mar 03, 2009 | Samsung HLT6176S Television
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
61 Inch = Fuzzy when connected to PC
Play with the resolution settings on the PC. That is the only thing you can do.
Jan 03, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
