Question about Olympus Camedia C-350 Digital Camera
CARD SET-UP When I open the camera to take photos it gives me a beeping sound and then a screen with two options:POWER OFF or FORMAT. If I choose the latter one the card warns me that it is deleting all. I'm afraid to do that because I have photos saved that I don't want deleted!!! Please help me!
  • 78 Answers
Save the photos using a card reader to your comp,then "format"it with the camera.
Posted on Dec 18, 2008
I need to set up the card on my Olympus C-5060 camera. When I choose the format button, it just beeps forever.
1. Power the camera off and remove and replace the card several times.
2. Recheck.
3. Put in another memory card and check.
If the recheck (2) does help, it may be dirty contacts.
If another memory card has the same issue, the camera needs repair.
Nov 27, 2011 | Olympus Camedia C-5060 Wide Zoom Digital...
How to format a sd card
Hello and welcome to FixYa!
1- If you want to format it by keeping in digital camera then follow the given procedure:-
  • Put the SD card into your digital camera and then turn the power on. Press the button on your camera to bring up your recently shot photographs.
  • Press the "Menu" or "OK" button on the camera to bring up the photograph options. Choose the option that says either "Setup" or "Options."
  • Scroll over to the "Format" option and hit "OK." Choose the option to set the file format to "FAT16."
2- You can also format it by connecting it to computer through card reader, For it follow the given procedure:-
  • Turn on your computer and put the SD card into the card reader slot on the front of your computer or the external card reader attached to a USB port. Wait to see if your operating system automatically opens a window prompting you for information. Click on the option to "Open a folder to view files" if the window pops up.
  • Click on the "Start" button if your operating system does not automatically prompt you to open a folder. Choose the "My Computer" option to bring up a new window.
  • Right-click on the drive bay for your card reader, and then choose the option that says "Reformat" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
You can also get help from the given video, if you choose second option
If you think this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 09, 2011 | Vivitar ViviCam 3720 Digital Camera
HOW TO FORMAT SD CARD
other way to format is Put the SD card in card reader and follow these steps:-
Right-click on the drive bay for your card reader, and then choose the option that says "format" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
good luck
hope it helps if so do rate the solution
Nov 29, 2010 | Kodak EasyShare DX4350 Digital Camera
I have a Polaroid a330 and just bought a 2GB sd card. The manual says to format a card before using and gives instructions. However, when I insert the card and turn on the camera, the screen shows "card...
first try to see if the card is not locked from the side ..It has a little button that locks it ...after that insert the card into a computer with a card reader ..and format it in Fat mode...by opening my computer folder...right click on the removable storage device ...and choose format ...when it opens choose Fat ..and quick format ..than OK ..this will format it for the first time ..and after that isert it in the camera and see if it is seen ..
if the format card is not available now..(to format it in the camera again and be sure it is the right way and make the folders fro storage ) ..
goto storage feature in the main menu ..and choose to store in teh card ..in tis moment will prompt you to format ...or ..just choose a picture from the camera memory in the view mode..and options ..and try to move it in the card ..if it is not proper formatted will ask you to format it ..and give you the possibility to make it right the way by asking you if you want to format it now...choose ok..and that's all..But I suspect that if you unlock it ..and format it in a computer will work like a charm ...
May 30, 2010 | Polaroid a330 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
I have just bought a new memory card for my Olympus D 390 camera, when i put the card in the camera it goes to a screen saying card set up, then gives the options of power off or Foemat. When i choose...
you need at least a 4 gb for it to read.. i just did mine too.. they are on sale right now at Target for $ 14.99, try this and let me know if this helped you good luk. tiffany in chattanooga tennessee
Jun 11, 2009 | Olympus Camedia D-390 Digital Camera
Locked photos on card
hey.. do not format ur card! just go to your pictures that u cannot delete and press menu and press playback options then you can see a key open it up to remove the protection on your picture... after that u can now easily delete that picture.. okay...
Feb 04, 2009 | Olympus Stylus 790SW Digital Camera
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Write protect
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - Press Ok- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Dec 28, 2008 | Olympus FE-230 Digital Camera
Can't take photos
Using a USB SD card-reader, copy all the photos from your camera SD-card to your PC, then try format option in your camera, this way the photos in your SD card are safe(in the computer). OR
insert a new/empty SD card into your camera. Use the format option and start clicking photos.
Dec 17, 2008 | Olympus Camedia C-350 Digital Camera
Olympus Camedia C-350 Digital Camera Logo
50 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
