Question about Sony CPD E230 17" CRT Monitor
Monitor Sony Trinitron monitor will not come out of "power save mode" I have unplugged and restarted several times. It is attached to a Mac G4 with OS X.
  • Anonymous Nov 02, 2007
    Dell Trinitron monitor will not come out of power save mode. Shuts down suddenly with no warning.
-Turn off both computer and monitor
-unplug monitor from computer(still plugged into power supply)
-turn on computer and monitor(monitor is still unplugged)
-After computer is on for about 30 sec. plug monitor into computer
-turn off both monitor and computer(now connected together)
-turn on monitor then computer and should be good to go!!!
Posted on Dec 26, 2007
  • 62 Answers
If the screen will not come out of power save mode it is generally the fault of the computer not pulling out of power save mode. Does the screen come out of power save mode wheny ou start the computer? If it does I would look at your settings and try and solve the problem on the computer side.
Posted on Mar 25, 2007
  • 4 Answers
Turn off the monitor;
Unplug the monitor from the computer;
Turn on the monitor;
Try going to the <menu> of the monitor, if there any menus avaiable you will see it, if the monitor stays in sleep mode probabily you have another problem related with some electronic protection of monitor electronics and then i think you sould take it to maintenace tecnitoin of your area,
Best regards, Creon
Posted on Aug 26, 2008
None of this is working
Posted on Apr 29, 2008
  • 624 Answers
Additional postings on this same topic can be found here as well: http://www.fixya.com/support/t139319-monitor
SOURCE:
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
My powerbook g4 screen is black what can I do?
Try restarting, if still not picture, then try hitting function key + F5 at the same time. Some laptops have a little icon the key that looks like a monitor as well.
If not try hooking up your laptop to a regular computer monitor and see if you can get a picture and fix the problem that way.
Jul 15, 2009 | Apple PowerBook G4 Mac Notebook
Windows XP in Power Save Mode and no buttons get it out
This can be solved in either of two steps.
>There should be "SPECIAL KEY" in the keyboard labelled as "SLEEP" or "STANDBY"...try clicking it..
<or>
>Check the monitor ON-BOARD settings for "POWER SAVER MODE".
Hope this will solve u r problem..
Plz revert back for any queries.
May 27, 2009 | Microsoft Windows XP Home Edition
My sreen powers of my desktop
Check your pins at the connector.  I had a problem like that before and it was a student who unplugged the cable and tried to reconnect but bent 2 pins which shorted out the computer and monitor.  If that isn't noticable try connecting the monitor to another computer or laptop and if it still does the shorting issue then its in the monitor cable or board on the monitor.
Apr 28, 2009 | Apple Power Mac G4 Desktop
No monitor works on my G4 Power Mac
If no monitor works on your Mac, but the machine is booting, the only assumption I can draw from this is a faulty display card.
Try another display card and see if this helps.
Regards,
Graemevm
Apr 19, 2009 | Apple eMac G4 Desktop
How do we turn off the POWER SAVING MODE on the monitor screen?
Try going into your Start Menu then going into your control panel...then clicking on your "power options"....then switching the options to 'always on'..if this does not work..(as it seems you may not be seeing this because the monitor is in power saving mode) try fiddling with the setup option on your monitor and find a possible powersaving mode enabled function and disable it. every monitor is different so I couldn't really help you here...if this doesn't yield results try another monitor to see if it's the monitor having the problems or the computers video card...the video card could very well be the culprit...
Apr 08, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Stuck in power save mode
Followed the directions of redlegs1, posted 12/26/2007. It didn't work the first time, but sure did on the second attempt. Thanks redlegs1, you're no apprentice my friend!
Apr 25, 2008 | Dell E173FP 17" LCD Monitor
Windows XP in Power Save Mode with blank screen
PC DESTOP ?
PC LAPTOP???
WITCH ONE DO U HAVE???
Nov 18, 2007 | Microsoft Windows XP Home Edition
Monitor
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t139319-monitor
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Monitor
Are you sure this is a monitor problem? I have a user with a Mac that occasionally has the same symptoms you describe. For me I generally have to shut the computer down and physically unplug the power cord from the computer (not monitor), reattach it and restart. Let us know if that works for you.
Sony CPD E230 17" CRT Monitor Logo
617 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
