By Perkins - usenet poster
I've got a Kenwood electric mixer I've used for years primarily to make bread dough. This past week while using it the mixing bowl started to rotate and come out of its base. Never happened before. I figured that the dough hook had to be turning now in reverse! This pushes the dough against the bowl side in the direction away from the stop in the base. Pushing against the stop keeps the bowl from moving. Can someone help?
Solution #1
posted on Aug 08, 2005
Pasty - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
The question poses yet another question which needs to be known. Does the machine have a reverse switch - If so, that switch may be stuck in the opposite rotating position, regardless of what position the indicator is in.
If there is a reversing switch, testing it using an ohm meter may reveal it is not allowing the motor to run in both directions. If there is no reversing switch, next to be known would be if the motor is reverseable...
If motor is not reverseable or never was reverseable, being sure it is infact currently reversing. May be more than meets the eye and more info specific to that models operations and functions that need to be known to allow more specific help to be provided.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Varimixer 746 Watts W20J Stand Mixer
Email this problem
Email this problem
This Problem Also Relates To:
Applica 200 Watts WHM6 Hand Mixer
Betty Crocker 210 Watts BCF1210 Hand Mixer
Betty Crocker 340 Watts BCF1250 Stand Mixer
Black & Decker 230 Watts MX95 PowerPro® Hand Mixer
Black & Decker 250 Watts MX250 PowerPro Hand Mixer
Black & Decker 200 Watts Ergo EHM90 Hand Mixer
Bosch 300 Watts MFQ2600 Hand Mixer
Can you Help with these Mixers problems?
Repair Service
Find Mixer Repairman Near You:
