Question about Toshiba 2060 Copier
Random C21 in Toshiba 2060
While copying, all of a sudden scanning mirror/lamp  strikes at the extream end instead of returning to home position making a sound. After that copies come out  sometimes black( no exposure lamp on) or with severe registration faliure.  After switching on/off the copier a few times solves the problem & the scanner returns at home position.  During this process, sometimes, not always, C21 is shown. Changed the home position sensor with no effect, changed logic(main) PCB also without any effect.  Pl. help.
    President:
  • Toshiba Master
  • 990 Answers
Dear sir; the toshiba copier they store the desciption in the memory therefor you just press "8" and "clear/stop" key simultaneously, It might be resetable, just turn machine off and back on. if you need more help please let me know,
HAVE A HAPPY HOLIDAY!!!
Posted on Dec 17, 2008
WHAT IS THE PROBLEM WITH SHARP AR-5620 SL WITH ERROR CODE L1
Mirror base feed trouble
The mirror home position (MHPS)
does not turn off though the feed
operation is completed during
mirror initial operation after turning
on the power.
does not turn off during shading
operation.
does not turn on when the mirror
base is returned for the specified
time after copy feed is started and
SPF scanning position shift is
performed.
Jun 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
How to reset error code C21 in The toshiba e-studio 206
[C21] indicates CIS unit initialization error.
Does the CIS case move to its home position when the power is turned ON?
If YES, check the CIS home position sensor follow by MAIN board.
If NO, check SCAN motor.
Oct 27, 2013 | Toshiba e-STUDIO166 Printer
My copier canon IR400 displays the error code E803,i need the meaning of the code.
Hello yaseen,
I just answered this question recently for someone. The fluorescent lamp that illuminates the image of the document you wish to copy/scan has become weak. When you first power up the copier it goes through a series of checks and adjustments to make sure you have the best quality copy. One of those checks is to turn the scan lamp on, that value is measured, and then the lamp voltage is adjusted up and down till it reaches a "target". If the target cannot be met(and in your case the light intensity could not be raised enough) then you will get this error code. I will try to help. To verify the lamp is even coming on, turn the true main power switch off. Then power up the copier and observe the scan lamp. At some point during the initial start up the lamp should come on for its measurement. In order to see this the document feeder must be in the up position. If the lamp does not come on then the most likely fix is a new lamp (we hope its not the circuitry that drives the lamp). So, if it does indeed come on then here's what we can try. ATTENTION!!!! the following suggestions REQUIRE that the copier is TOTALLY UNPLUGGED !!!. This is a DANGEROUS AREA to be near if the copier is plugged in ! OK? Ok, remove the large copy board glass. On your device I believe there are 2 screws to the right of it that allow you to remove a cover which then allows you to remove the glass. Clean it thoroughly on both sides keeping in mind the orientation of the glass. set it aside. Now by hand , slide/pull the scan lamp assembly to the right, the direction it moves naturally as it scans a document..There will be some slight resistance. Locate the lamp and with a moist(not wet) soft cloth clean the lamp. Follow that with a dry soft cloth. Make it perfectly clean especially at the ends. Notice the shiny reflectors around the lamp.Clean those as well. While you are there, clean the 3 mirrors that bounce the light/ image. Just look for 1 mirror below the lamp, and 2 mirrors that are located to the left of the lamp, the distance of the 2 mirrorrs from the lamp will vary depending on how far you move the scanner/lamp assembly.Now here's the part where I have to help you visualize something that I can't point to and that you never new existed so bare with me.
There is a plate you need to clean that is to your left. If you push the scanner all the way to the left until it stops you will have found the scanner's "home position". When the copier first comes on and does it's checks it turns the lamp on (while at its home position) and reflects light against a plate called the "standard white plate". It is used as a referrence for what "perfect white" should be. It needs to be cleaned. So move the scanner to the right again so you can get to the area where the lamp would have looked at if it were "home" and doing it's self check. You can't see it, but its an area that would be above the lamp if it were home.So its underneath what you see. Clean it as well. Just clean everthing in that "underneath area". Same method, perhaps a bit of glass cleaner HERE only. Use as many soft cloths as needed. Ok, finally, wipe the actual lamp itself off one last time with a moist cloth and a little alcohol. The lamp needs to be free of the oils of your fingers. Make sure everthing is clean and dry. We want everything to be bright and shiny. Now re-install the copy board glass and power the copier up. Now there is no doubt that the lamp is weak, but it may be able to now boost it's ouput enough to hit the "target" it needs to. I hope this helps. Take care, and let "FIXYA" know if I did indeed help. :-) SPINAL
Mar 12, 2011 | Canon imageRUNNER 400S Copier
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
When making a copy system error [L1-00] appears what should i do
Hello sir; That's scan problem, scan did not leave home, did not return home, scan overloaded, mirror motor problem, or scan cable came off. check all the factor it cause the problem.
Dec 23, 2009 | Sharp AL-1655CS Copier
Got a sc141 and 142 on a ricoh mp5000. Have cleaned the lamp and associated mirrors and have reseated the connectors at the lamp and sbu. i have run the scanner free run with the lamp on. there is no...
SC 141 -Lens vertical home position sensor abnormal stays on
When the lens returns to the home position the lens vertical home position sensor does not detect the off condition.The possible cause :home position sensor open,lens vertical drive motor defective or optics control board defective.
SC 142 -Lens horizontal home position sensor abnormal stays off
When the lens returns to the home position,the lens horizontal home position sensor mot detect the on condition.Possible cause :home position sensor in shortcircuit,horizontal drive motor defective or optics board defective.
The SC can be reset by turning main switch OFF and ON if the SC caused by misdetection.
Scanner free run
Remove the rear cover and the air inlet duct.Remove CN502,CN503,CN504 from the optic control board.Create short circuit TP 514 and GND on the optics board.Turn ON the main switch.Short circuit TP 512 and GND then the machine automatically starts the scanner free run.Turn off the main switch.Perform the scanner control adjustment.Enter in the service mode:press the clear modes key - 107 -press the clear/stop key more 3 second until the service mode appears.Perform the free run test mode 30 times.
Sep 19, 2009 | Ricoh Office Equipment & Supplies
Leaving a black line at the top of the page
make sure paper guides are secure other then that could b dirty optics (mirrors under the glass) or drum / fusing unit
Feb 26, 2009 | Toshiba 2060 Copier
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Sep 04, 2008 | Toshiba 2060 Copier
159 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Computer Links
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
