Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The garage door has power coming to it . When I press the remote the unit makes a humming sound but nothing happens at all
  • Anonymous Dec 19, 2008
    I have the same problem making a humming sound or it sound like a clicking noise in the motor.
  • muthomas Dec 19, 2008
    I also have this problem. It hums and continues until I press the remote control twice before it stops. I am unable to use the control.
    Champion:
  • 244 Answers
Clicking can be an overheated motor from trying to much. other idea is troley opened too far and lodged against bolt on rail by motor.
Posted on Jan 15, 2009
Garage door opener won't work
Motor has overheated; the motor unit does not operate or trolleyis stuck on stop bolt = Motor unit hums briefly; RPM Sensor =Short travel 6-8" (15-20 cm).• Unplug unit to reset. Try to operate motor unit, check diagnostic code.• If it is still flashing 5 times and motor unit moves 6-8" (15-20 cm), replace RPMsensor.• If motor unit doesn't operate, motor unit is overheated. Wait 30 minutes andretry. If motor unit still will not operate replace logic board.
Aug 30, 2012 | Craftsman 3/4 Hp Garage Door Opener System...
LiftMaster garage door opener won't open. When push button (from either remote or "door-bell" style button on wall), unit makes a slight humming sound for a couple of seconds, then nothing...?
Check the door springs and also the drive gear. The gear is a white nylon gear just in front of the motor unit. It will be pretty obvious if it is going bad. The door spring may be broken.
Oct 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unable to open the garage door with the remotes. I closed the door from inside unit and came out. but later on when i tried opening it from the remote there is nothing happening. Please please help me. My...
It sounds like your remote may have deaad battery OR got de-programmed. I hope you have another door into the garage. You NEVER should rely on a radio remote as the ONLY access to the garage! Many failures can happen to prevent the remote from working.
IF you can kill the power to the opener in the garage, do that for a couple minutes then repower and try again...
And for goodness sakes cut in a new door as EVEN in a condition where the power fails in a disaster you want to have access to your vehicle... this is a "wake up call" for you! There is also a keyed lock that can give you access to the manual trip cord to allow manual opening of the door.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftman Garaged Door Unit Stopped Working
This sounds like you will have to replace the logic board. Whether you repair or replace get a surge protector 900 joules or higher unless you want it to happen again. You can get replacement parts at searspartsdirect.com. Thanks BB
Oct 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Oct 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
262 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
