Question about Magellan Maestro 4040 GPS Receiver
Problems with Magellan Maestro? 4040 GPS power connection
Yellow piece inside unit which the powercord plug is broken off. I opened the unit and I did not break any connections. So can I just just solder the yellow piece where the power cord plug into The same thing happened to my 4040 yesterday. The jack in side of unit pushed inside, can no longer plug it in.
  • 5 more comments
  • Anonymous Jan 08, 2009
    magellan Maestro. sn. 0726400652235.  Yellow power connector broken. Previous returned unit to factory for same problem. Fixed for a few months.
  • jrnkat Feb 03, 2009
    How do you get it open
  • Anonymous Feb 05, 2009
    Yellow piece is floating inside
  • jhgfd Feb 07, 2009
    yellow plug went inside the unit cant charge anymore
  • Admiral Elm Feb 27, 2009
    Yellow power plug broke off inside the unit. How do I get the unit open now to solder it back on?
  • Anonymous Mar 03, 2009
    The power jack on my 4040 broke off!  It was from normal use!
  • ohjohnny May 11, 2010
    How can I get case open to resolder yellow Jack?
I also have the same problem - the yellow power jack has broken connections. I fixed it by soldering it back. In my unit, the connection pads under the external power jack were intact and I was able to solder the jack easily. The audio out jack nearby has also come-off the PC board, along with the pads. I am not able to re-solder these back. Since the audio jack is part of the speaker circuit I have lost the text-to-speech function!
Hope you are able to fix yours.
Posted on Dec 31, 2008
Port for car charger broken
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Jul 05, 2010 | Magellan Maestro 4040 GPS Receiver
Can I fix loose charger inside the unit of Magellan Maestro 4040?
  1. The only way it can be fixed is to replace thew whole motherboard. about $90.00
please rate our help to keep free sewrvice online
Aug 30, 2009 | Magellan Maestro 4040 GPS Receiver
Loose part at the power input point.
it comes apart take out the 4 screws in the back. you'll need something to pry the back off .start on the side with something thin to unsnap the 2 halfs then use your fingers. after openning you'll need to resolder the powerport back on with a soldering iron and new solder. 4 spots hold the powerport on. it will be stronger than before. mine worked fine after.
May 03, 2009 | Magellan Maestro 4040 GPS Receiver
Meastro 4040 wont charge reliably
I had the same trouble exactly. The yellow power input socket has a pin and shield connection that must be contacting the center and side of the power input plug. I opened the Magellan and found that one side of the shield contact had never been soldered to the PC board. It was only a matter of time and use, before the piece moved up and away from the outer part of the power socket. A dot of solder solved the problem. The case for the Magellan is easily opened by removing four very small screws from the four corners of the black back and then prying the silver framed screen from the back exposing the printed circuit board. I am sure this completely voids the warranty with Magellan, but they will not repair out of warranty units anyway. Be aware there is a connector from the screen that is plugged into the circuit board. This is easily pulled apart with a pair of fine needle nose pliers and replaced the same way after the repair. The soldering should be done by someone with PC board assembly experiance.
Handy John
Feb 21, 2009 | Magellan Maestro 4040 GPS Receiver
I have the Magellan Maestro 4040. The yellow power connecter has come lose/off and is inside unit. I can't seem to figure out how to open unit
You have to use small screw drivers to open unit and re-align the yellow connector. Maku sure that when all screws are undone. Pry it open carefully not to misplace or misalign any other parts. If the connectore is really broken from the connector board, we need service technician to either solder it for you or replace some parts on the connectore board itself.
Jan 17, 2009 | Magellan Maestro 4040 GPS Receiver
Wow if you opened the unit Magellan can tell. If your unit was under warranty You might have talked them into a repair (if your very very very persistent with you can get thin done , eventually ) but now you talk to them to see what they can do but it may be cheaper to go get another unit
Jan 12, 2009 | Magellan Maestro 4040 GPS Receiver
this is a very common problem with these magellan 3140 and als the 3100,2000,2200t,2500,4000,4040 and the 4050most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ...to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Broken-off power connector
most likely the power port is damaged and needs replaced.i repair those magellan gps if you need help. if i cant fix it there isno charge. wmetz@comcast.netto open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Nov 05, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan model MAESTRO3100
if you need the power port for your gps, i have them for 2000 2200t 2500 3100 3140 4000 4040 and 4050 magellan maestro and roadmate
Oct 25, 2008 | Magellan SITEX 236/120ST TM 120KHZ -...
hi ,
I understand from your mail that the power pin in the unit has been broken.
contact the Technical Support at 1-800-707-9971 so that they will give you a RA number and the address for the repair center.
Mar 07, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
566 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
