Kenmore Elite washing machine will not fill as fast as usual.
Kenmore Elite Heavy Duty washing machine will not fill as fast as usual. Temperature does not seem to make a difference on fill time. I have read to check the water inlet valve and filters. Is this correct and how do I do that?
  • sherigifford Dec 17, 2008
    That is exactly what I did and wow, it works, Thanks. As a Mom of 4, my washer is my handy helper. I had to use CLR and a Q tip to clean out the iron build up, but it worked great. Thanks for the prompt response and helpful suggestion.
    Novelist:
  • 161 Answers
You will need to get behind the washer, turn the water off, disconnect the hose from the washer, look for a screen inside the water valve, hopefully there is one that you can clean if necessary. I always put the hose over in the washer and turn the water on to check the flow.
If the screens on both hot and cold are clear, water flow is good on both hot and cold, connect the water back to the washer. If the flow is still slow then the problem is inside the valve. The valve will have to be replaced.
Posted on Dec 17, 2008
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
Kenmore elite heavy duty king size top loader water will not stop running to the liquid detergent dispenser even when the tub starts filling Causing the machine to over flow
could be the water valve not closing properly, try unplugging the machine see if the water stops if not replace water valve. Also check pressure hose for cut and pin hole thx
Mar 01, 2014 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
No agitation in the delicate and regular modes.
does you washer have a delicate, or normal speed adjustment switch, if it does make sure its not between setting or it will sound like a machine gun......you may need to replace that switch
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer
I had our washer repaired several years back and the guy said it was a problem with this model and we should NEVER use any cycle but the heavy duty. The only way to reset the machine was to let the machine run through its cycle one time (stopping and starting). Once it completes - everything goes back to normal unless somebody decides to switch the wash action to something other than Fast/Fast.
Sep 22, 2007 | Washing Machines
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
