Question about Kodak EasyShare Z700 Digital Camera
Current drain Can anyone tell me the acceptable current consumption for this model? I have one on my bench that seems very battery hungry, more than any other digital camera I've worked on. Yet the batteries are not getting hot.
    Problem Solver:
  • 8 Answers
I had that problem so I just brought rechargable batteries. I was fairly pleased with them.
Good Luck
Posted on Feb 05, 2008
My Saturn Vue is 2003 it has a new battery but won't hold a charge for more than three days. Several mechanics have said the car must be driven regularly to keep the battery charged; that there is no
Were were told pure nonsense by those mechanics
Forget other folks vehicle problems
All vehicles worldwide have many issues
They can do a Parasitic Current Test -- by leaving all the doors
closed & the key out of the ignition & have an Amp Meter in
either battery cable,then you wait for all modules & relay's to
time out (go to sleep)
IF-- you have a current draw over 50 to 60 Milli-Amps after an
hour --you have to start pulling fuses, to locate the circuit with
a problem & your battery drain
For your Alternator-- there are many tests & ways to do them,so do not assume the shops you went to, are on their game
My guess is that no shop has actually put time into the problem
& there may be many reasons why. That part I won't share with you,as it is not easy in that business dealing with the public, that hate you & the prices you charge.
Nov 22, 2014 | 2003 Saturn VUE
Tip
Which solar panels can be used with Imeon?
Because Imeon inverter is transformerless, only two types of PV modules are acceptable: mono crystalline and poly crystalline. Do not connect any PV modules that may introduce leakage current to the inverter (such as non-grounded PV modules). Refer to technical datasheet of the PV modules.
NOTE : The PV DC voltage and current must be within the MPP range of the MPPT Input. Refer to product documentation
imeon energy -solar-hybrid-inverter-imeon3.6-45-┬░angle-view--wigaoetmofgu4i3phjlbvsds-5-0.png
self consumption autonomous house inverters solar batteries Imeon Energy
on Mar 12, 2018 | Inverter Electronics - Others
I have a 2002 K1200LT. It seems that the battery is losing voltage and does not start the bike. It is a second new battery and is charged. When charged it starts the bike ok but after a couple of days it...
It sounds like there is something draining your battery such as an alarm. I would start by charging the battery up and checking the bike starts ok. Then totally isolate the battery and wait a few days. Reconnect it, does the bike start? If no, then its a bad battery (just because its new doesnt mean its good).
If you have a multimeter you can use this to find what is causing the problem. This can be acheived by putting it in series with the battery. There will be some current drain, but no more than around 50mA. If you have a larger drain then start by removing one fuse at a time and see if the current drain reduces to an acceptable level.
This should then help identify which circuit is giving you the problem.
Oct 14, 2013 | 2008 BMW K 1200 GT
2001 Jetta TDI Battery drain??
If you suspect the alternator, disconnect the 12V line coming directly from the battery and check for current drain. Are you sure the current unit is in ampere (A) and not milliampere (mA)? A 5A current will drain your battery in about an hour. A 5mA current is just about normal considering the parasitic load (radio memory chip, clock, ECM memory circuit, etc.). Try checking your battery. It could be the real culprit.
Mar 16, 2017 | 2001 Volkswagen Jetta TDI
Subaru legacy power lose when switched off. new battery charge rate 14 volt+
The charge rate of 14 volt shows that your alternator is responding as it should and is doing its best to recharge the battery. Even with a fully charged battery if you switch on the power hungry electrical items (main headlights, rear window demist heater etc) you should see the alternator respond by pushing out 14+ volts. A low battery will show about 12.2 volts when disconnected. OK you need to find what is draining your battery when the car is switched off. With the car off disconnect the negative terminal and measure the current flowing between the disconnected cable and the negative terminal, it should very very low, just enough to keep the clock running. If you do have residual current flow, remove and return each fuse one at a time and note each time the current reading. Quite quickly you will be able to isolate the circuit that is causing the drain. Often it is a lighting circuit for an interior light that you cannot see....such as a glove box light not going off when the lid closes or the trunk light staying on. These work by a contact switch being opened by coming into contact with a bracket when shut. If for some reason the bracket gets bent or is dislodged then the light stays on.
Jun 01, 2010 | 1992 Subaru Legacy
What is the standby power consumption of the Bush 2878 N televisi
contact manufacturer with entire model number.back of tv will only tell you current draw when its on.
Sep 18, 2009 | Televison & Video
Having problem with draining battery, alternator checks good on bench test, battery checks good and starter checks good. need help where can i go next to fix this problem
Since you bench tested the alternator, and the battery has good capacity (hopefully isn't 5 years old or more), the next logical step is to do a leakage test.
Disconnect one of the battery cables (either one, I'd go with the negative one) and insert a 12 volt test light between the battery and ground of your car. Now, any current draw must go through the lamp. If it is lit with "nothing drawing any current" you can now look further for the offending circuit. Usually simple stuff like aftermarket alarm system, trunk light staying on, that sort of thing.
Even try removing fuses one at a time to localize which circuit to check.
Good luck.
Apr 27, 2009 | 1996 Chevrolet Cavalier
1993 Cougar Specs
I made an electrolizer my Corolla and a smaller unit for my 150cc scooter. I got tons of bubbles so I expected stunning fuel consumption. In the end I chucked them out because they made no difference either to the power or the consumption. Remember, your alternator will be working flat out all the time to keep up with the energy needs and this alone will affect your consumption. Secondly, your engine management system will notice that your car is running leaner and will richen the mixture to compensate. More fuel consumption. You might find that you will put a lot of effort in for little or no return. The only solution for high fuel consumption, apart from a properly tuned car, is a lighter foot.
Jan 13, 2009 | 1993 Mercury Cougar
Cpqusbfw usb hub
i have one of those hubs the ac adapter is output +5V, and current 0.2 - 2.5A, inside of connector is pos(+), outside is neg(-), input: 100 - 120 Vac and 0.45A Max
Aug 30, 2008 | Micro Innovations Compaq CPQ24USB
Why does my battery gauge seem inaccurate?
In a variable-load high power device such as a digital camera, the battery level indicator gives a prediction of remaining battery life, based on current rate of consumption. Since different operations consume different amounts of power, the battery gauge may appear inaccurate if changing the operations being performed by the camera, which changes the rate of power consumption.
Aug 30, 2005 | HP Photosmart 120 Digital Camera
Kodak EasyShare Z700 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
