Question about Lexmark T644dtn Printer
Setting print count on Lexmark T644
How do i set the page count on a Lexmark T644 printer?
  • 2 more comments
  • Anonymous Mar 17, 2014
    I need to get a page count on this printer. Can you tell me how to do it.
    how to I get a page count from a lexmark E260dn
    Can you help me find where I can do a page count from this printer.
I'm assuming you mean the maintaince counters... Turn off the printer. Press and hold the check and right arrow buttons on the front of the printer
Turn on the printer. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. Select Reset Maintenance Count from the Configuration menu. The message Reset Maint Cnt=Reset displays momentarily. Press Check to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
  • Alejandro Rosales May 11, 2012
    Very Helpful. Right to the point. No extra google searh needed...
HORIZONTAL LINES ACROSS T644 PRINTER AND 930.00 ERROR CODE
The error code 930.00 indicates a problem in the laser print head section of the printer. This will cause error in the printouts like you are having. This type of problem is not user serviceable and will require an authorized service dealer to obtain and install the printhead assembly. This is directly from page 2-24 of the service manual.
Jul 24, 2012 | Lexmark T644 Laser Printer
Separator Sheets with smiley faces
Attempt to restore printer to factory defaults to cure this issue.
Sep 06, 2017 | Lexmark T644 Laser Printer
How to fix,if every time somebody send to printer Lexmark T644 shows error message:"change tray 1 to color letter? thank you Bella Touro College lab tech
Have a look in the preference settings of the printer driver and check the paper type. If this is set to color letter you'll have to set the traysettings to the same type of paper. Best is to set both setting to normal paper.
Jul 27, 2010 | Lexmark T644 Laser Printer
How do I print the meter page count on a lexmark t614,t612 and t520?
Use the following steps.
1. Press the menu button multiple times until you get to Utilities Menu.
2. Press Select.
3. Press menu until you get to Print Menus.
4. Press Select.
A Menu Settings page will print. Following all the menu settings a page count will be listed. This applies to all three models.
Jun 23, 2010 | Lexmark Optra T612 Laser Printer
Lite toner marks on paper
The imaging drum is included in the toner cartridge on this one, so you could need a new toner cartridge. If that doesn't fix it, then you are looking at either the transfer roller or the fuser needs replaced. Workgroup printers usually require a maintenance kit after 300,000 pages printed, fyi. that kit includes feed rollers, a fuser, and a transfer roller. Not sure what the page count is, but that could help you figure it out.
Nov 03, 2009 | Lexmark T644 Laser Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
Lexmark T644 network settings missing on menu
These are options that you must add via the Network Setup Menu.
Don
LEXMARK T644
Make sure that the toner is not leaking and check your connections from the HVPS. If they look good I would replace the printhead.
Roger
Sep 10, 2008 | Lexmark T644 Laser Printer
691 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
