Question about SanDisk Sansa e260 MP3 Player
E260 setting buton is no functioning Help - SanDisk Sansa e260 MP3 Player
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 24, 2008
Why will my canon pixma mp250 not reset a refilled color cartridge
i dont think you where trying the right solutions. the mp250 catridge 511 can not be reset as far as i know. what you can do to get it to print is to long press the reset button. this disables the ink level check function and you can work. the procedure you stated is usually for resetting the ink absorber, not catridges.
Good Luck!
Jan 16, 2013 | Canon Pixma MP250 All-in-One Color InkJet...
My sandisk sansa e260 mp3 player wont trun on it goes to the start up screen and thin keeps repeting that screen how can i fix this does any1 know?
Hi, the Sansa E260 is a portable MP3 player released by SanDisk in 2004. Several problems may cause the E260 to not function as intended from time to time. Common problems that occur are the device freezing, album art not appearing on the screen when a song is playing, pictures not filling the screen size and missing information on the separate tracks. You can troubleshoot the device and fix many of these common problems without the need of a service technician.
Reset
1. The Sansa E260 may freeze or function in other unexpected ways from time to time. This generally occurs when the unit's software has developed an error. Reset the device to clear the error and return the device to normal working operation. A unit reset is similar to rebooting your computer. You won't lose any data stored on your device.
To reset the E260, press and hold the "Power/Menu" button for about 15 seconds. The device will be forced to power down, during which the error will be cleared. You can restart the E260 as normal once the reset is complete.
Album Art Does Not Display
2. The E260 supports viewing album art on the display screen during the playing of a song. You may find that your album art is not showing up on the display when music is playing on the device. To fix this, make sure the associated album art file is in the same folder as the song being played. You will need to connect the E260 into your computer to move the album art files into the music folder.
Photos Aren't Full-Screen
3. Photos displayed on the E260 will not show up as full-screen shots if they are not cropped to the correct dimensions. The E260 software does not support stretching pictures to fit the full screen. To ensure your photographs will display on the full screen, crop the images to 128x64 in photo-editing software prior to transferring the image on the E260.
Unknown Artist or Album
4. The E260 displays information about each song using the ID3 tags associated with each track. ID3 tags hold information such as the artist name, album name, track number, year it was released and other information. If the E260 shows an artist or album as unknown, the information in the ID3 tag was not filled in. You can insert information into the ID3 tags from your computer.
To change the ID3 information, right-click on the music file and choose "Properties." Click on the "Summary" tab and choose "Advanced." The ID3 fields will display in the window. Insert any of the missing information and click "OK." When you upload the song onto your E260, the newly inserted information will show up in the display.
Hope it helped...
Feb 23, 2011 | SanDisk Sansa e260 MP3 Player
My window media direct buton now work as a power buton what is the reason and how can i correct it
Media direct functionality requires that the hard drive be partitioned by the Media direct utility, then windows installed then the Media direct application installation and then the utilities it uses (PowerDVD etc)
if Windows has been reinstalled and things were not done in that order, then the function of media direct will not work.
Dec 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
Security Code Kenwood RC-527
press the buton number 1 until you set your first digit code,then press buton number 2 until you set your second digit code,then press the buton number 3 until you set your third digit code,then press the buton number 4 until you set the 4th digit code,finally find the DISP buton and keep it press it untli you see this APROOVED.
May 02, 2009 | Kenwood Car Audio & Video
I have Windows Vista and it says that it can't support the sansa e260
I would place the e260 in MSC mode first, as Vista should support this Sansa.
Unplug the player, then from the e260 do the following:
go to Settings, then choose System Settings then USB Mode & select MSC. Next, connect the E260, Vista should now see the player properly.
Mar 19, 2009 | SanDisk Sansa e260 MP3 Player
Sansa E260 - I don't have USB Mode on my settings
Go look under Menu > Settings again. Either go UP two choices or down eleven choices and there it is.
Dec 23, 2008 | SanDisk Sansa e260 MP3 Player
Activate T Buton gose to Alarm function.
As with many watch manufacture houses novadays watch technology differs from house to house. Tissot is no difference as T-series watches was developed by Tissot itself.
You have to follow the steps one by one as instructed in your watch manual. Probably you will need reset your watch completely, depending what actions you've allready done.
In case if you lost your watch manual, go to www.tissot.ch and find out everything you need.
Regards
Arthur
Dec 16, 2008 | Tissot T-Touch T33159851 Wrist Watch
Auto shut to work
This function is kind of confusing. It will not shut the player down while music is playing. It's just basically a battery-saving function. Say you leave your player on and not playing. After set amount of minutes it'll shut off to save battery life, but not if it's playing music. Odd function, eh?
(btw, this is what i've found to be the function and may not be 100% right.)
Aug 25, 2008 | SanDisk Sansa e260 MP3 Player
Toshib E-450 fax confirmation.
Press the user functions button on control panel
Press Admin button and key in password and then ENTER
press the LIST/REPORT button
press report settings
press COMM.REPORT button
then press desired butons for each item
press enter
hope this helps!
C
Aug 22, 2008 | Toshiba Saddle-Stitch Finisher Copier
SanDisk Sansa e260 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
