Question about Samsung LN32A330 32 in. LCD TV
Can you provide parts list (part #'s) for ln32a330 lcd tv pedestal stand? My assembly manual indicates that there is the stand, a plastic ring, a guide stand, 3 (a) screws and 4 (b) screws. Any others? I would like to order some of these parts.
    Problem Solver:
  • 8 Answers
This is the link to parts for your model tv. I hope it helps! :)
http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=LN32A330J1D&modelid=512510
Posted on Feb 05, 2009
How to remove pedestal stand from Samsung ld
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs are given with illustrations. Gopakumar Gopalan Google
Aug 05, 2014 | Samsung LN32A330 32 in. LCD TV
How to assemble tv stand
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 10, 2014 | Samsung LN32C540 32 in. LCD TV
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
Stand of our Samsung LCD TV LA32C530F1R is broken!! Where and how to get new spare stand??
WILL YOU PLEASE INFORM ME DEALER FOR THE SAMANG TV MODEL LA32C530F1R SAPRE PARTS AND THEIR CONTECT NUMBERS IN AHMEDABAD LOCAL.
Oct 22, 2012 | Samsung LN32A330 32 in. LCD TV
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
Sharp aquos lcd colour tv model lc52le700e i need an orginal stand for this tv where can i get it if possible at all
I found this available on www.encompassparts.com.
log in as a guest, enter your model number, the first three parts listed for this tv are,
Stand support, Stand base assembly, and stand screws. Total cost for the three items $ 108.00
I checked E-bay and found none.
Jul 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Where can i buy a plastic tv stand for my sylvania LD299SL8. It got thrown away when we wall mounted it. now i want it to sit on a stand
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
Dec 14, 2010 | Sylvania 6427FB 27" TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
Note: Extreme care should always be used when removing
without tools.
sliding the pedestal stand away from the TV.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Samsung LN32A330 32 in. LCD TV Logo
675 people viewed this question
Jerry Greenberg
Jerry Greenberg
