Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
LaCie 2d 500GB isnt recognized
On windows XP, plugged in (USB2) a Lacie 500GB 2d Safe HD, shows up as Drive E: but when I double left click on it, message says "No media Loaded", troubleshooting doesnt help, tried on 2 other computers for the same result. Upgraded the drivers, tried older versions also.
thanks alot.
Marc
    President:
  • 1,179 Answers
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Posted on Dec 21, 2008
I bought a few years ago a Lacie d2 safe hard drive with AES Encryption (with biometric fingerprint sensor). Currently not my Toshiba desktop or IBM laptop pick up the hard drive when I switch it on. The...
Hi... Problem with your external hard drive, pc don't recognize it...
it possible you have bad sector in your disk drive, or your usb cable is not responding.... the best way to find out open your box then take off our hard drive and install it into a pc and see if the hard drive work... or you box it self the controller inside our external box maybe damage,
Oct 20, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have the Lacie Rugged hard drive 320,undetectable
Since you have tried connecting the hard drive (HD) into two computers (Win7 and Vista) and both of them had the same problem, you may want to try replacing the cable of the HD.
Another thing, try connecting the HD into a Windows XP computer and see if same thing will happen. If you're hearing a clicking sound while the HD is turned ON, I'm sorry to say but the HD is no longer working. That clicking sound is also called the "Click of Death".
Thank you!
Dec 10, 2009 | LaCie Computers & Internet
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500GB was formatted for MAC and given for use on PC. It does not show up anywhere when plugged in, blue light on. pc says device detected, but does not recognize and it does not show up in control...
You will need to format the device for Windows use. If you can see the device in My Computer, right click it and select format. if you can't see it in My Computer, you will need to use a boot tool such as Gparted: http://gparted.sourceforge.net/download.php
Download the .iso file and burn it as an image to a cd, then boot from the CD at startup. It should detect the 500 Gb drive and allow you to format it to NTFS. Then Windows will recognize it.
Mar 09, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie Silverscreen 80Gb Drive not recognised by My Dual Processor PC
Sorry for the late reply, but it may help someone else with the same problem.
Are you using a USB2 port, perhaps it's may not be getting enough power. In the orginal Lacie box was a double USB dongle - it allows you to take the power from two USB ports and send them to the Silverscreen, if the SScreen was getting quite enough power.
Or buy a double USB power cable (like: http://www.n-c.fr/webshopncrevendeurs/catalog/images/Double_Cable_USB.jpg)
Otherwise remove the 2.5" disk (remove two screws, & gently pull out) and use a caddy to check the HD disk is still working.
Aug 10, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB P3 got the clicking sickness
There are companies that can recover the date from the disk of a failed hard drive, check online, It is expensive.
Apr 20, 2017 | LaCie 500GB P3 HD USB 2.0 7200RPM 8M 500...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
641 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
