Question about HP Compaq Evo n610c Notebook
Problems with Compaq Evo n610c
I have an Compaq Evo n610c and the keys are not working is that a motherboard problem?
    Sergeant:
  • 366 Answers
Use a compressed air can to clean under and between keys.
(Power off)
Posted on Jan 14, 2009
Keys i,i5 is coming up 5 and o,o6 is coming up 6 on keypad on Compaq Evo n610c
there should be a key that says number lock or NUM or similar. Press this once and it will take the number lock off and return your keys to normal :D
Nov 28, 2009 | HP Compaq Evo n610c Notebook
Problem loading os on compaq evo n610c
Make sure you start by deleting the old partition, and formatting C:. If it still locks up after that, then your hard drive is bad.
Nov 21, 2009 | Compaq Evo N610C Notebook
Problems with HP Compaq Evo n610c PC Notebook - keys m, v, spacebar not responding when press.
Most likely there's some grit or dust inside the keyboard key contacts.
Begin by placing the powered down PC on a side, blowing compressed air from above (so that it enters between the keys laterally), top to bottom, with a compressed air bottle. Check all keys.
There are also specialized notebook keyboard cleaning kits.
If it didn't work, you may try prying the keys open - "peel" the keys from below, pulling gently, careful not to break the tiny plastic studs - and exposing the contacts pit in the middle. Blow air inside to clear the contacts.
If not even that helps, you may need a replacement keyboard - you'll find cheap ones on eBay, http://www.pchub.com and elsewhere.
Oct 26, 2009 | HP Compaq Evo n610c Notebook
Can you help me please, how can I do a screen print on a Compaq Evo N610C. Thank you
Hold down the Ctrl key and then press the PrtSc key.
Then open MS Word and on a new page Press Ctrl key + the "V" key to paste the image in the Word document.
Apr 26, 2009 | Compaq Evo N610C Notebook
HDD upgrade for compaq evo n610c
i have a compaq evo n610c with a 160 gig hardrive and a gig of ram a bluetooth top adapter and installed a wireless card with antennas it works fine and reads the hardrive fine and i get the 158 sumthin sumthin gigs that it alwase turns out to be the fans a going harder thoe thats bout it and the batt dies sooner
Nov 27, 2008 | Compaq Evo N610C Notebook
Evo n610c key board
try going to control panel sysyem find the keyboard and click on it and remove it. Then go to contron panel then add and remove programs and look for any programs that say evo.and remove it. hope this helps you out.
Nov 25, 2008 | Compaq Evo Notebook Keyboard N610C/N600c
Can I install 1gb of ram on a compaq evo n610c
Yes, Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs to a max of 1gig - and two 512 would be perfect.
The memory modules in a Compaq Evo N610C are not located where you expect them to be.
Here's how to do it.
Open the notebook, and place your fingers on the keyboard as if you were going to type. There is a panel directly beneath your left palm, just below the Ctrl and Alt keys. The panel is hooked into the front of the frame closest to you. Using a thin flathead screwdriver or knife blade, apply a bit of pressure on the panel so that you're pushing it towards the LCD while prying it up. The panel will come right off and you'll have direct access to the memory modules.
Jul 28, 2008 | Compaq Evo N610C Notebook
COMPAQ N610C DISTORTED DISPLAY?
Sounds like video failure. If your video is integrated as most laptops are, it will require a motherboard replacement.
Jun 27, 2008 | Compaq Evo N610C Notebook
Compaq evo 610
Turn it all the off. Then pull the hard drive out and put it back in again. Now, put your system disk (Win XP?) into the drive and turn the laptop on. It should do something else now. I have had this happen on several laptops I have rebuilt and it takes patience to get them started sometimes.... I have managed to load XP onto all of them eventually!
Hope this helps
Apr 04, 2008 | Compaq Evo N610C Notebook
Compaq evo n610
Your problem is that MOTHERBOARD can't detected HDD.Try with another hdd and let me know if it works!!!
HP Compaq Evo n610c Notebook Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
