Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Canon multipass 390
I can fax if I dial directly using the keyboard on the fax/scanner/printer. If I scan a document and want to fax via pdf program (it's faster to fax this way) it will not fax. It was working. Have not added any new hardware or software. HELP. I can scan into email and it works fine. Thanks! Pam
Alarm is flashing and flashing put in cartridge even though I've put in both black and color new cartridges and reset both still won't print
Posted on Oct 26, 2008
I need a free user manual download for a Canon MultiPass MP 390
You can get check it here:
http://soft-manufaktura.ru/manual/hp/mp390sm.pdf
Nov 15, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
Tip
Canon MultiPass Mp730 Drivers And manuals for Windows computers.
Here I will show you where to find drivers and documentation for the canon MultiPass mp730 photo printer - copier - fax - scanner.
Driversfor this printer are available for Windows 98, windows ME, windows Xp, WindowsVista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation foryour printer please visit
THIS PAGE
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, macetc )
3. All available drivers, documents etc will beavailable below.
For some of the documents a PDF reader may berequired to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdfreader(s)
Thank you for reading and I hope your printer isup and running again.
-Ekse
on Mar 11, 2010 | Office Equipment & Supplies
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
How to programm my fax number
Here is a link to your Canon LaserClass 9000 users guide, unfortunately it was scanned 90 degrees off.
http://www.actcopiers.com/Manuals/LC9000.pdf
Setting up group dial will allow you to send to multiple locations with only one scan of document(s). Programming fax number should be located on page 3-5.
Oct 16, 2009 | Canon LaserClass 9000L Plain Paper Fax
How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
Mar 30, 2009 | Canon MX310 Office All-In-One Printer
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
How do I scan and e-mail pdf documents from the MP730?
Scanners scan a document in picture format(JPEG) dot per dot. Their are complete programs out ther that will scan a document and turn it into a text fine. They are far more expensive that just copy a picture of some words on a page, Typical scanner function. I hope I have explained it well.
Feb 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Canon MultiPASS F50 won't copy but will scan
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
313 people viewed this question
old marine
old marine
