Question about Tomtom GO 700 GPS Receiver
Tom Tom Go 710 - Won't turn on
Hi, my Tom Tom Go 710 ran out of battery and when I plugged it in (in my car) and tried to turn it back on it wouldn't, although the green light was on to show it was actually charging. I then tried to reset it and the green light came on as I pressed the reset button but still wouldn't turn on.
At home I connected it to my computer with the Tom Tom program running and managed eventually to get it to turn on and charged the battery. But when the charge ran out it wouldn't charge up again in the car or turn on?
Any ideas?
Thanks
Ally
  • 6 more comments
  • Anonymous Dec 24, 2008
    same with mine
    The green light comes on the TomTom 700 GPS unit when plugged into the cigeratte lighter in the car, but unit will not come on. I have pressed the reset on the bottom of the unit, green light is on, but unit will not turn on.
  • malahat_hofs Dec 27, 2008
    I have same problem like ally wont turn on and there is nothing on the display!
  • Anonymous Dec 27, 2008
    I have the same problem with mine. how do you fix it?
  • Prop PC Feb 02, 2009
    I have a similar problem, although my Tom Tom never actually ran out of gas. It just wouldn't turn back on. I have tried to re-set it etc. with no luck!
    Any ideas - other devices work in the cigarette lighter!
    Paul
  • Anonymous Feb 17, 2009
    GO Model 4V00.710 with battery charged will not
    turn on. Screen glows pale blue. Is there a reset button?
  • darrenlfrost Feb 27, 2009
    Same here, as described below. Sounds like a fault with the unit?
  • brianlee1 Mar 14, 2009
    I've ordered a replacement battery through megacity.com and will see if this will work. Evidently, there is no charge left in the battery even after hours of of charging. I'll repost when the battery arrives. There is a website to open up the unit and replace the battery.
  • 3 Answers
Not sure but try an other device on the car plug to see if it works??????????? could be the plug.
Posted on Dec 21, 2008
Hi all
I've now got the same problem with my TomTom GO 910. Thought I'd post what I've replaced:
I've replaced the battery, the car lead, the car dock and I've tried it in other vehicles - no luck. It charges ok from the main in the desk dock. Looks like it's a fault with the device it's self. Pity, been really happy with it and now it looks like it's time for a new one.
Sorry for the non solution!
Posted on Jul 21, 2010
Tom tom go 710 will not switch on
I guess that you have already made sure the battery is charged enough to power the Sat Nav.... In the back of the Tom Tom where the cradle attaches, there is a tiny hole at the top where you can insert a small object such as a sewing needle in order to press the reset button; However, you may find that like mine the hole doesn't line-up with the button and therefore you can't reset the unit unless you remove the casing. if this is the case it's best to search You Tube and watch the short video as to what exactly to do! (it's really not hard)
Hope this helps
Aug 12, 2012 | Tomtom GO 710 Car GPS Receiver
My Samsung behold ran out of battery this morning and it was dead for an hour or two. After I plugged it in to charge for a couple minutes, it still wouldn't turn on. After several attempts of taking...
Sounds like a battery problem. Seems your battery is completely dead. Get your cellular provider to order you a new battery. That should fix your problem.
Jul 06, 2011 | Samsung Behold Cell Phone
Where can i get a manual for a tom tom 710
download.tomtom.com/open/manuals/...710.../TomTom_GO_EN.pdf
Try this.
Jul 11, 2010 | Tomtom GO 710 Car GPS Receiver
My tomtom will not turn on. I have had it plugged into the car charger for several hours. Help?
try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
Jan 02, 2010 | Tomtom ONE GPS Receiver
Hi, Tom Tom 710 has not come on for weeks.
it doesnt get better by itself. Despite having a green light doesnt mean it is charged. try changing the battery
Jul 05, 2009 | Tomtom GO 700 GPS Receiver
Tom tom won't turn off
if it does not proceed when the icon is selected, presume data corruption or in fact no data.
TomTom is renouned for this type of problem.
try rteinstalling the map data from the source.
try a reset first ( small pinhole on rear) put open paperclip end in and gently push the button inside) if this still fails then data installation is the go
Jun 23, 2009 | Tomtom GO 720 GPS Receiver
Tom tom wont turn on.
turn device over and look for tiny reset button near to power connect strip. then use a blunt safety pin to reset,this should allow you to then turn it on,this works on 500 ,700 ,900 , 510 , 710 , 910 , hope this helps .
Jun 06, 2009 | GPS
Recently after working one day the next day when i tried to use mt tom tom 710 it wouldnt switch on but the mains light was lit when plugged into cig lighter
Try giving it a full charge. I used different model Tom Tom that would not turn on even if plugged in until after the battery was recharged.
Oct 10, 2008 | Tomtom GO 700 GPS Receiver
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
1,956 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
