Question about HP Compaq Evo n610c Notebook
Hey I have an Compaq Evo n610c and the keys quit working is that a motherboard problem or what?
  • 24 Answers
Probably just a loose connection.
Turn computer off,
take screw in middle of bottom of computer out,
turn back over and open computer and slide small bars between the function keys (eg esc and F1, F4 and F5, etc) down.
Tip the computer over and the keyboard should fall out. If it doesn't, gently pull down on a function key and it should come out. If it doesn't, check your work and confirm all 4 of the slide bars are down and the screw is all the way out of the bottom.
There are 2 connectors for the keyboard. One a thin cable and one a wide cable. You problem is the wide cable, for the keyboard. The other is for the trackpoint/touchpad.
You will see a point on the motherboard, close to the bottom of the keyboard where this wide cable connects to the motherboard.
Slide the connector on the motherboard up (there's a small tab on both sides of connector) and the cable will come free. The cable itself is just like a wide piece of ribbon.
Clean off the end with a piece of tissue and slide it into the connector as far as it will go, then push the tabs on the side down to connect the calbe to the motherboard.
Lay the keyboard back down and turn on computer to see if your problem is resolved.
If it is, turn computer back off and reconnect everything.
If it's not fixed, it could be your keyboard has gone bad (buy one on ebay for $25 and install) or you have a motherboard problem (unlikely).
If you search for service manual for a n610 you should be albe to find a PDF file with drawing illustrating the above.
Good luck...
Posted on Dec 25, 2008
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
Oct 12, 2010 | HP Compaq Evo n610c Notebook
Keys i,i5 is coming up 5 and o,o6 is coming up 6 on keypad on Compaq Evo n610c
there should be a key that says number lock or NUM or similar. Press this once and it will take the number lock off and return your keys to normal :D
Nov 28, 2009 | HP Compaq Evo n610c Notebook
Can you help me please, how can I do a screen print on a Compaq Evo N610C. Thank you
Hold down the Ctrl key and then press the PrtSc key.
Then open MS Word and on a new page Press Ctrl key + the "V" key to paste the image in the Word document.
Apr 26, 2009 | Compaq Evo N610C Notebook
Problems with Compaq Evo n610c
use a compressed air can to clean under and between keys.
(Power off)
Dec 17, 2008 | HP Compaq Evo n610c Notebook
Evo n610c key board
try going to control panel sysyem find the keyboard and click on it and remove it. Then go to contron panel then add and remove programs and look for any programs that say evo.and remove it. hope this helps you out.
Nov 25, 2008 | Compaq Evo Notebook Keyboard N610C/N600c
Can I install 1gb of ram on a compaq evo n610c
Yes, Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs to a max of 1gig - and two 512 would be perfect.
The memory modules in a Compaq Evo N610C are not located where you expect them to be.
Here's how to do it.
Open the notebook, and place your fingers on the keyboard as if you were going to type. There is a panel directly beneath your left palm, just below the Ctrl and Alt keys. The panel is hooked into the front of the frame closest to you. Using a thin flathead screwdriver or knife blade, apply a bit of pressure on the panel so that you're pushing it towards the LCD while prying it up. The panel will come right off and you'll have direct access to the memory modules.
Jul 28, 2008 | Compaq Evo N610C Notebook
Sounds like video failure. If your video is integrated as most laptops are, it will require a motherboard replacement.
Jun 27, 2008 | Compaq Evo N610C Notebook
Compaq evo n610
Your problem is that MOTHERBOARD can't detected HDD.Try with another hdd and let me know if it works!!!
Apr 04, 2008 | Compaq Evo N610C Notebook
HP Compaq Evo n610c Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
