My display light is so dim that I can't see the time, temperature or the timer minutes.
1 Other User Has The Same Problem
Comment by dak373, posted on Jun 05, 2008
Our oven panel reads nothing, but when you turn it on , it heats and it beeps to the desired temp. After awhile the panel will start reading when it gets hot and up to temp. What's up?
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
While at it, I went ahead and replaced the other 3 electrolitic caps on the module ( 2# 470uF 35V & 1# 22uF 50V). I just figured these caps also might have or would soon dry out due to prolonged exposure to high temperature. It important to replace with high temperature rated capacitors.
In the first place, I think this is a design flaw and these guys should not have used electrolitic caps knowing these will exposed to high ambient temperature for prolonged period. They should probably have used tantalum capacitors.
Thanks a lot for the posting, I too saved about $150 by not replacing the entire clock module.
Suresh
Your fix worked perfectly....I could only find a 100uF 35 v but it works just fine......Saved $168 which was the price at the Whirlpool supply house.
Thanks !!
Don
Based on the above solution, I took a crack at it. It was easy to remove the front panel and to remove the clock/display board. I desoldered the original C3 capacitor (68uF, 35V) and replaced it with the closest I could find (68uF, 63V) and the display is now back to normal.
Thank you! By fixing this instead of replacing the entire clock/display board, I saved $150 and kept the otherwise good board from ending up in a landfill.
Its real easy to do if you're handy.
IMPORTANT Turn circuit breaker OFF first
Open oven door
From underneath control panel remove 4 white screws with philips screw driver
this holds white cover strip
remove 4 hex head screws which will loosen the panel.
remove panel and support it's weight as many wires are connected.
remove 2 small plugs on board - you may need a small screw driver to pry away the locking mechanisms on the socket
Remove riggon type flat cable by squeezing black tabs on eand and lift up.
The board can now be removed by unclipping 2 of the clips holding the board while lifting up.
Take board to Radio Shack and ask for a suitable replacement for the C3 cap which is 35 volts and 68uf (microfarads). Remove and replace by careful soldering.
If traces lift off oard use a wire to jumper trace
ensure the cap goes in the same polarity there is negative signs on one side.
You can parallel caps to add uf together.
Voltage should be not less than 35volt slightly higher is OK.
Comment by Moscow Dan, posted on Dec 04, 2007
Email me, I can probably help you out.
Delrosecop@netzero.com
Post a New problem for Jenn-Air SCE30600 Slide-In Electric
Email this problem
Can you Help with these Kitchen Ranges problems?
Jenn-air JES8850AAB fan makes a...
how do you remove the ccokk top...
Jenn Aire model 30600B
Cooling Fan Issue With Power...
ge electric stove
