Question about Mitsubishi WS-55807 TV
HD Setting How do I change the setting from standard to HD without a remote?
    New Friend:
  • 61 Answers
In display settings set the resolution at 1080i
Posted on Aug 09, 2012
SOURCE:
How can i increase the bass on pioneer htd-510 without remote
I have tried many different ways gave up don't think you can BUY A REMOTE I DID
Aug 19, 2012 | Pioneer HTD-510 System
I have U-verse in conjunction with my Phillips TV. Last night we accidently changed the aspect ratio from 1080ip to standard non definition wide screen. We lost the pictures but had sound. I spoke with...
The easiest solution is to replace the box. Otherwise, you can try leaving the unit unplugged for a day or more to drain the power and ideally reset the box.
Feb 28, 2011 | Philips 34PW9818 34" TV
I have a toshiba 27a33 without a remote and i am unable to change the tv/video settings. is there any way i am able to change the setting manually without a remote? Thank you.
Hello
Sorry. Your TVs front panel has no menu button to press. The only way to chane it to AV/TV, cand be done with its remote control which ahs that button to press. You just buy one new remote control, of get the present one repaired. OK.
Dec 06, 2010 | Toshiba 27A33 27" TV
I am running a Sky + HD box through my television Hitachi 26LD6600 using a HD lead. I have balanced the sky remote to the tv, but whenever we turn to Sky/digital tv we have to manually change the tv...
Hi, without a manual to hand, i don't know, but my Panasonic had the same problem, but I found somewhere in the settings, I could change it, it has something to do with AV and Digital TV and hdmi setup, give it a check.
I hope this helps to some degree, but give us a shout if you require more help.
Regards - Anthony
Feb 06, 2010 | Hitachi 26LD6600 26 in. HD-Ready LCD...
How do I remove the ''sap'' setting without the original rca remot?
You can use your front panel buttons & it should tell you (display) which button does does what function.
Jan 03, 2010 | Televison & Video
Synergy V rt-u64cp remote to control Receiver volume
For those who want your audio device volume to work without changing modes here's how: hold cable and select until cable lights up - then press volume+ and then press audio. That's it.
Apr 06, 2009 | Televison & Video
I have a samsung 1080i 52" floor model tv. I don't have a remote or the instructions,. I have hd box from rogers and my picture doesn't fill the screen, Rogers said I have to do it either with a remote or...
you will need a remote to change the picture setting to make it fill the screen! try a cheap universeal remote that you can get at any wall mart
Dec 07, 2008 | Televison & Video
Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Feb 17, 2008 | Daewoo DVN-14F6N 13" TV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Mitsubishi WS-55807 TV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
