Question about Audiovox JE2043 20 in. EDTV-Ready LCD Television
The TV station just ran a test and our Jenson JE2043 in our motorhome does not receive the new digital signal which becomes effective in February. What do we need to do to be able to receive the digital signal? Thanks. Sue
  • sue6776 Dec 17, 2008
    Do they make converter boxes for 12volt TV's? Thanks
  • spidersuds Feb 24, 2009
    I purchased the analog convereter to use in my motorhome, but the analog is 110 AC and I want someting for 12 volt system, is is possible
    spidersuds@centurytel.net
    President:
  • 2,992 Answers
You'll need one of the new converter boxes and possibly a new antenna. The US Gov't has been issuing $40 coupons toward the purchase of basic converter boxes, and some places have set prices so that you basically get them free. You can get up to 2 coupons from www.dtv2009.gov.
Once you have the converter box, you leave your TV on channel 3 (or 4, depending on how you set it) and do your channel changing with the box.
With the new digital broadcasts, signal strength is more important than with analog. You might need to upgrade your antenna if all you have is a small pair of rabbit-ears. The only way to know for sure is to see what channels the box finds with your current antenna. There are a bunch of different indoor antennas to choose from if you need one, and outside antennas as well if you really need the pull.
The downside to all this is that you may wind up with fewer channels to watch, depending on your area. If you were able to get a fuzzy but watchable picture on analog, the station may not be strong enough for digital. You don't know 'til you try it. The picture quality of the DTV signal is much better, though.
Hope this is helpful...please feel free to rate my answer as you see fit.
Posted on Dec 17, 2008
  • Dec 17, 2008
    Interesting question. I have not seen a converter box directly offering a DC input, but that doesn't mean nobody makes one. Probably your best solution would be to get a small inverter to convert 12 volts DC to 120 volts AC. For the power needed by the converter box you wouldn't need a huge capacity inverter. Wal-Mart, Radio Shack and probably a large auto-parts store would have them. Wal-Mart's site lists a few in the $20-$30 range, Radio Shack's prices are a few bucks higher.
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Can not get all my local channels
May Be becouse Antenna On Top Of Roof Is to old, Plugging cord in wrong place plug in: In
Mar 25, 2009 | Curtis-Mathis CM19011 TV
I have a Hitachi 32CX38B, does it have a digital tuner?
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
Dan
Jan 28, 2009 | Hitachi Televison & Video
Hitachi 57G500A DTV & upcoming analog to digital changeover
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Converter Box Problem
That just means that stations you can't pick up while the box is on are not broadcasting digital signals yet. Most will be after February.
Oct 29, 2008 | Insignia Digital-to-Analog Converter for...
DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Oct 10, 2008 | Zenith C27A24T 27" TV
2006 RCA TV Digetal Receiver
NBC newsperson said I should check nbc.com to learn
what to do for the change in February. Where is it ??
You want my solution ? Improve your web site.
Feb 23, 2008 | Televison & Video
RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
Feb 10, 2008 | RCA P52939 52" Rear Projection Television
Audiovox JE2043 20 in. EDTV-Ready LCD Television Logo
141 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
