Question about Epson Stylus C43UX InkJet Printer
The ink cartride does not stop at the middle
The ink cartrides do not stop in the middle even with the top cover opened.
  • 353 Answers
The cartridge carrier/print head is not supposed to stop in the middle unless you are changing a cartridge - is this what you are trying to do? How to do this is clearly explained in the manuals - see
http://tech.epson.com.au/downloads/message.asp
for clear explanations of how to do this.
Posted on Feb 13, 2009
Does not print in black
cartridge 21 is out of ink , open the cover and when the cartridge moves in the middle pull out the cartride and be check for refill if not bye a new one, thanks and good luck.
Jul 10, 2011 | HP C4795 AllInOne InkJet Printer
Why it can't print?
It won't print if your ink cartridge is empty. Check the black and white and also the color cartrides by doing the following:
1. Slide your hand underneath the front cover and open up the case.
2. Find your ink cartrides usually located on the left on the inside of the casing.
3. Gently pull up (usually) on the cartridge and take it out and shake it. You will know if it is empty or full when you shake it. If the color is full but the black and white is out that is probably the problem. Many printers won't work if the black and white cartridge is empty because that's usually the primary color.
4. Go to Walgreen's or a similiar store and purchase a new cartridge and then just reverse the steps putting it back in. Make sure you take note where each cartride is located when taking them out and put them in their correct position when you put them back in.
This should solve your problem and you should be printing again in no time flat!
Dec 22, 2010 | Epson Stylus Photo R390 InkJet Printer
How do I change ink cartridge in the lexmark x4690?
Here's an article on How to Set Up the Lexmark X3600 or X4600 Series All-In-One. Just click on this link and follow the instructions: http://bit.ly/cI3Ekr. This should give you an idea on how to change/replace the cartrides.
In some cases, the ink cartridge carrier won't position itself in the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the white tape in the middle inside the printer. The other end of it is connected to the carrier. Gently slide the carrier to the center. Load the cartridges. Close the cover. Plug the printer back to power source.
Aug 18, 2010 | Lexmark X5470 All-In-One InkJet Printer
How to insert inkjet print cartridge
Open the printer cover>press the button with the ink logo/picture and the carriage will move to the middle and stop. Open the cover of the releveant ink you want to change and remove it. remove the strip with the arrow on the new cartride (should tell you how to do this on the box or foil wrapper), and gently push the new catridge back in place. Close the ink cover then close the printer cover then press the ink logo again. This should send the carriage back to the right hand side. Some models then automatically send out a test page.
I hope this helps
Oct 25, 2008 | HP Office Equipment & Supplies
CANNOT CHANGE INK CARTRIDGE,CARTRID GE IS ON FAR LEFT SIDE OF PRINTER SO THAT i DO NOT HAVE ACCESS TO IT. iT IS A MODEL 8300.
turn off machine, open and get a knife (or something flat) and put on top of the cartridge and push down, then try pulling to the middle.
The problem is that somehow the latch that holds the cartridges is open.
Aug 20, 2008 | Lexmark Office Equipment & Supplies
Need to change ink cartridges
With the cover closed, press the Ink button. Then follow the instructions in the lcd readout.
Jun 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How to change ink cartrides
on ur printer , open top cover of printer, ur ink cartridge will come on center of printer, pull ink cartridge ur side , now u can replace ur cartridge
ajay
9329204658
May 09, 2008 | Office Equipment & Supplies
Printer out of paper error on HP694c
  1. Turn the printer off and open the cover.
  2. Lift the right black rectangular paper sensor (located in the middle of the printer just below cartridge slides) clean it up, try with vacum cleaner first if it does not help use coton swabs and clean it.
Good luck
RC
Jan 30, 2008 | Computers & Internet
Need your assistance please
OPEN COVER OF FAX AS IF YOU ARE ABOUT TO INSTALL INK CART YOU WILL SEE A BIG SILVER BAR THAT THE INK CARTRIDE TRAVEL ON.
APPLY a couple of drops of 3 in 1 oil to the top of this BAR close cover and turn fax machine off and back on then fax should start working again
Jan 16, 2008 | Canon FAXPHONE B740 Plain Paper Bubblejet
Epson Stylus C43UX InkJet Printer Logo
185 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
