Question about D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337)
Lan 4pc by nic card
Hi friend.....salaam malikum
plz tell me how can lan 4 pc by nic Or evdo card bsnl.....
    Genius:
  • 1,269 Answers
You can simply use or buy a router. Router will automatically network your computers without any special configuration.
Posted on Dec 19, 2008
While installing BSNL evdo card in tat INTF0 system cannot find the path specified
when installing drivers let the PC install where it wants to, do not change anything yourself or specify a different path, hit the enter button and yes button when you are f=given the option to choose.
May 02, 2015 | Computers & Internet
I want to start internet in 4 computers what can i do for. i have a bsnl broadband connention. PLz help me
Hi Friend, In this case I would recommend you to please check if the BSNL modem is the wireless modem or the Wired modem. If it is a wireless modem then you can connect your system wirelessly to internet , provided that the laptop has the wireless card in it.
If it is a wired modem then you can connect your system with the LAN cable to that modem in each slots to get connected to the Internet.
Dec 09, 2010 | Intel Computers & Internet
Micromax high speed cdma modem model:-mmx 200c meid:-A100000B407CD6 S/N:- 1003C001959 Please send unlock code Thank you.
micromax high speed cdma modem
model:-mmx 200c
meid:-A100000B40731F
S/N:- 1003C0029472
And i want insert BSNL EVDO card pls help me
Thank you.
magesh
Oct 13, 2010 | Computers & Internet
Is nic and lan card same.
NIC/LAN are the same.
Regards.
May 27, 2010 | Intel Pentium 4 1.7G, 1.7 GHz...
I did and esn change from my old phone to a voyager 10000 the black one. when i start making a call it reboots....what can i do to the phone to fix it
sam in evdo im using zte evdo bsnl
1-my one friend evdo is useless he give to me and se do r&d on this device
2-my other fried brought new evdo from bsnl office i just try to make clon of evdo for surfing
then i get sucess 100% both are working but from last two day my secend one is not getting network
but i try again and i had change the prl and switch to cdma mode then i get sucess secend time 100%
but now i want to make this device to orignal condition but esn is not changig like write protected but i had chandet many time now it making prroblem plz give me any suggetiin
Dec 12, 2009 | LG VOYAGER VX10000 Cellular Phone
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Sharing
well that was easy, you havent detailed any problems to rectify.
assuming there is a connectivity problem sharing the broadband connection,
buy a cheap router, or switch, and install between the cable modem and all 4 pcs
Jun 28, 2008 | Intel Motherboard
I want lan card driver for fmv-6100mg2
buying a lan card is costly..........u can hav the same adv by buying a modem of bsnl which has lan and wifi for the same rate which is usb connected to the comp
Mar 29, 2008 | Fujitsu AMILO D-7820 Notebook
LAN card not installing
u can use any brand . there's no problem in that . installation procedure is very simple. just buy a pci lan card. Insert it in the pci slot. Then switch on your computer , insert the driver cd provided with your lan card , then install the appropriate drivers.
Then, you can connect BSNL Broadband by connecting your ADSL modem with your LAN card.
Hope it helps..
Regards
Grydor.
Mar 06, 2008 | Computers & Internet
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
70 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
