Question about LG Flatron L1515S 15" LCD Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello, I am using L1515S 15" LCD Monitor. Is there any for the monitor to support 1280 x 1024 Resolution. Please give me a solution. Regards mallik
    Novelist:
  • 198 Answers
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Posted on Mar 25, 2007
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
Input signal out of range
Your PC video resolution is too high or this monitor to work, you need to lower it down to the native resolution of this monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 17, 2011 | LG Flatron L1515S 15" LCD Monitor
LG Flatron L1515S 15" LCD Monitor Problems & Solutions
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 18, 2010 | LG Flatron L1515S 15" LCD Monitor
Out of range 64.0 kHz / 60 Hz
Unfortunately if you cannot get the resolution down, you cannot use it.
Jun 18, 2017 | LG Flatron L1515S 15" LCD Monitor
Screen goes blank and message comes up saying "input signal out of range"
When does the screen go blank? Also what do you have plugged into it this most likely just because your input signal may be set at to high a resolution or frequency. Once I have more information I can assist you further.
Thanks,
Lee
Aug 11, 2009 | LG Flatron L1515S 15" LCD Monitor
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Monitor won't light up. Only just for a second or two.
Hi
this issue is made by defective torch or lamp at the back of LCD...
Thanks!
Aug 05, 2008 | LG Flatron L1515S 15" LCD Monitor
Reducing resolution
Set the resolution you want to use in the GAME. Under the Settings heading, when you go into the game!
damnor01
Jul 14, 2008 | LG Flatron L1515S 15" LCD Monitor
LG Flatron L1515S 15" LCD Monitor Logo
277 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
