Question about Swisher 60" 26 Hp Zero Turn Radius Riding Mower #Zt2660b
Need owers manual
Need this manual because i need a drive belt for this unit.
  • gparks106 Dec 17, 2008
    need to know where to go on line to download and print off the manual.
  • 43 Answers
Http://www.swisherinc.com/manuals/PDF/ZT2660Rev_08-016.pdf
Posted on Dec 19, 2008
Tory biltm ower big red horse
You have this posted in the wrong product category. Please re-post the question in correct category.
May 31, 2012 | Cars & Trucks
How to repair alternator
take ower the belt drive loose 3 scrous and cheng bearings and regler
Nov 12, 2010 | 1999 Chrysler 300M
Routing diagram for a Serpentine Belt for 2003 pontaic aztek
normally that info is posted on a sticker under the hood or on the rad support of the vehicle you may also fine it in the owers manual
Sep 11, 2010 | Pontiac Aztek Cars & Trucks
When turn on fan sounds like it need greasing and
If you are refering to the indoor blower, you need to shut off the ower to the unit, open the blower chamber and check the cleanliness, build up of dirt and debris in the squirrel cage can sometimes cause vibration. Check the "end play and see if there is considerable play in and out on the motor shaft, also check the mounting brackets to verify the intergity of the mechanical connections. If it is a belt drive, it could be the bearings, the bearing mounts or the cage itself if it is belt drive then consider changing the unit as it is well past time!
Jul 12, 2009 | Carrier Heating & Cooling
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
Need a ower manuaal for 459rog laptop
You can obtain user/owner guide manual and technical specs of your gateway in the link below.
Please leave feedback
Thanks
http://support.gateway.com/s/Manuals/Mobile/8510056.pdf
Apr 28, 2009 | Gateway 450ROG Notebook
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Swisher 60" 26 Hp Zero Turn Radius Riding Mower #Zt2660b Logo
440 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
