Question about Panasonic DP-C213 Color Copier
Stopping and clearing printing jobs
When there is a print job going and you what to cancel it how do you do that? I've tried the stop, clear, interuppt, cancel buttons none of them work. Please help so we can stop wasting paper. Thank you
    Problem Solver:
  • 12 Answers
From the control panel, lower right corner, select "output queue", select "print" tab, select the job you wish to cancel, select OK.
Posted on Jan 06, 2009
My officejet x576dw has no memory job to big and cancels my job how do I fix this please
The memory in the printer may be defective. Deleting the print job clears the memory.
Feb 19, 2017 | The Office Equipment & Supplies
HP 1500 will not stop Printing
Printer of all types connet to a computer and make use of a spooling service on the computer. You may need to go into the Printers and Faxes section of the computer from the Start button and open up the printer you are using and right click on all the documents that are listed there and click on cancel. There is a relationship between printer and computer with handshaking so you need to cancel and let the printer be connected to cancel the jobs. Pull out the paper tray might be a way to have it stop printing while to cancel the jobs. The cancel or clear on the printer only affect the jobs held in the memory on the printer and then as soon as that is clear the next job from the spool comes in. Clear printer spooling and then the printer should stop.
Jan 30, 2013 | HEWLETT-PACKARD Hewlett Packard Products -...
How do you clear the print jobs so that you are not printing the same things over and over
How to Clear Out a Stalled Print Job In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Once you have restarted the Print Spooler, the jammed print job will be cleared from memory. Now you can go back and re-print all the jobs that were held up.
Feb 15, 2011 | HP Office Equipment & Supplies
I sent a print job to the printer and it started to print and just stopped. The ink, paper, & power source lights all began flashing simultaneously. There was no paper jam and the ink cartridges are...
make sure there is no pending print job in print spooler if it is there then clear it before giving the print .for clearing In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Nov 21, 2009 | Epson Stylus 880 InkJet Color Printer
How do I clear a paper jam ?
just open the printer cover and switch it off the printer and try to pull out the paper slowly and cancel all the print job from print queue.for clearing the print job you can go to run window and type services.msc and the go to print spooler option just stop and restart the service.
Nov 16, 2009 | HP Photosmart D7260 Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
How to stop the printing job of my printer?.it can't be canceled
Clear the print queue by double clicking the printer icon in the Printers and Faxes folder and power off and unplug the printer power cord. Remove the paper from the tray and power the printer back on if it attempt to print again repeat the process until the memory is cleared.
Jan 23, 2009 | Office Equipment & Supplies
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Panasonic DP-C213 Color Copier Logo
176 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
