Question about Dishwashers
Kenmore dishwasher starting and stopping
I have a Kenmore DW model #5871551590. I hadn't used it for awhile, I cleaned the inside out, ran it through one cycle with some vinegar for the hard water deposits, ran it through another cycle with bleach for the scum and odor. Next time I tried to turn it on, it filled with water, the motor came on (actually the humming noise sounded like it was coming from the door), hummed for 5 or 6 seconds, then shut off. Now that's all it'll do. It won't drain the water that's in it, and the motor won't start. The door makes a buzzing sound for a couple seconds then quits. Is there a problem with the connection in the door? Any help would be very much appreciated. Thanks in advance.
Something buzzes inside, sounds like a small compressor
sounds like your pump is stopped up or clogged and not able to turn. The pump is on the bottom side and usually the dw will have to be taken out to remove it and replace or clean it.
Apr 08, 2011 | Kenmore Dishwashers
My 6 year old Kenmore Elite DW has started leaking and has a musty smell. The dishes are clean but food residue is left on the inside door and black gunk builds up on the bottom of the dishwasher.
Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
Mar 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
My Kenmore dishwasher starts to fill and then stops
I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
Oct 04, 2009 | Kenmore Dishwashers
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
Water does not drain completely,water from sink backs up in DW
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jan 31, 2009 | Caloric 24 in. CDU510C Built-in Dishwasher
Hi. I have a 3 year old LG dishwasher. It will not drain. Display shows OE. I completely cleaned the drain assembly inside the DW. I checked the discharge line, it is completely clean. I disconnected the...
Measure the electric resistance of the Drain Motor. (Value should be 20-40 Ohms) If it is out of spec, replace it.
Please reply with what worked best. Thanks!
Dec 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Kenmore Portable Dishwasher
Go to Sears.com if you have a Kennmore. Under "parts," you can input your model number, which is found on the inside of the washer on the side, and then search for the part. It even has a diagram you can pull up. Unfortunately, this part for mine, and probably yours will only be available by purchasing the entire hose outfit, (about $65).
Aug 29, 2008 | Kenmore 17252 Free-standing Dishwasher
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
Oloyede Monsuru
Marvin
Marvin
