Question about Creative Labs ZEN Stone MP3 Player
Limited downloads on mp3 player
Hello, mp3 player will not accept more than 115 songs when capable of 250. Solution would be greatly appreciated. The mp3 player is spi 1g
  • fe_man Dec 25, 2008
    We bought three of these ... so far I've started uploading songs to two and have run into the same problem. I tried different mixes of songs and it didn't fix any thing, or allow any more songs on. Both players show less than half full (more than 500MB remaining). I scanned one for errors... none found.
    Help!
  • fe_man May 11, 2010
    If my songs were of a higher bitrate... the drive's memory would show full. This is not the case and why I posted that each player showed more than 500MB remaining. Any other ideas?
Probably because your songs are at a very high bitrate eg. 320 (CD quality) as opposed to 128 (average quality). Songs at a higher bitrate take up more space. So the Zen Stone can hold 250 songs at a bitrate of 128 but only, say, 150 at a bitrate of 320. Your solution would be to use http://www.dors.de/razorlame/index.php to decrease the quality of your mp3 & make the file size smaller.
Posted on Jan 10, 2009
I have a Phillips 4gb mp3 player. I downloaded some music to my player and when I went to listen to those songs I couldn't. I picked one of the songs and would play another song. It shows it playing on the...
Hello :
Reset your mp3 player first . If that didn't solve the problem , then I would recommend you to format your player . But before formatting you need to back up everything on it .
good luck .
please rate !
Apr 01, 2010 | Philips GoGear Flash MP3 Player
Iriver T10 2Gb does not work
I would suggest you to give the mp3 player to the cuustomer care store it will help alot. Thanks.
Jan 01, 2010 | iRiver T10 MP3 Player
I downloaded music onto my element gc-820 then go to listen and it says no file what the hell
The following may help:
- Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format). - Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. - Lastly, if you have put your song with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player)
Dec 19, 2009 | Sears GC-820 MP3 Player
It wont play the downloading songs
Dec 19, 2009 | Element Electronics Zr-Element Digital...
I downloaded songs of my windows player and my mp4 player will only play the songs for ten seconds then skip to the next song.
That player is not capable of recognizing most song formats. You must download tracks that are only in Mp3 format or NONPROTECTED WMA format. Most WMA's are protected nowadays, and therefore won't work with this particular player.
-Tha Mp3 Doctor
Jan 10, 2009 | Audiovox MP4128 MP3 Player
Won't accept music downloads
The Media Manager is for pictures and video only - use Windows Media Player to transfer songs.
Dec 29, 2008 | GPX ML648B MP3 Player
Transferring Audio Filles
The songs are perhaps in the wrong format.  This player will not accept copy-protected iTunes (AAC) files.  Also, the license on your files may not permit transfer to mp3 players. Definitely check the bitrates on your files, b/c this Sony can only accept certain ranges of bit rate.
This is my general spiel about music formats, but note that your Sony does accept DRM-protected files with transfer rights, so not everything in the following blurb applies fully to you: All of these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC (iTunes), WAV, RA, etc.  In addition, every file format type is in a certain bitrate, size, etc.  By far the most common issue is that the music file contains a license or copyright (especially with WMA or AAC file formats).  Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.   If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu.
Mp3 player product documentation is not straightforward.  If a player supports only non-protected WMA files, it will merely say that it supports WMA – it will not tell which type of WMA it supports.  A player that supports DRM-protected WMA’s will usually indicate such on the box (usually with a Windows Plays For Sure logo – which is actually an ironic misnomer).  DRM stands for Digital Rights Management, and it is a type of licensing system for WMA files.  It is used extensively by mp3 player music services such as Bearshare, LeapFrog, Napster, and others.  Not all DRM licenses are created equal – there are licenses with “play rights,” burn rights,” and “transfer rights.”  Play rights mean that you can only play the song on your PC – it will play fine on your computer, but it will not play in your mp3 player even though it appears to transfer.  Burn rights mean that the song can be burned to CD.  Transfer rights mean that the song can be transferred onto an mp3 player that supports DRM-protected files.  Then, there are unlimited licenses and limited licenses.  Limited licenses only allow you to play a song for a certain length of time. You would have to pay extra to continue using the song after that trial period is over – the time length ranges from a few days to several months or longer.
-Tha Mp3 Doctor
Sep 09, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Songs to my mp3 wont download
try putting them on a cd then ripping them to the hard drive then put them back on the sandisk
Jul 08, 2008 | SanDisk Sansa e250 MP3 Player
Sony walkman 1 gig mp3 player not downloading songs
hola soy de panama y necesito el driver o el programa de instalacion ya q el cd se me daño
May 20, 2008 | Sony Walkman Bean NW-E307 MP3 Player
Sansa 250e player - synchronize message
You have no capacity in your firmware for this audiobook to be "OKed" on your device. You therefore cannot play it! Sorry for the bad news! but your device does have limited playback capabilities! please mark this as solved, i would appreciate it!
Jul 27, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs ZEN Stone MP3 Player Logo
76 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
