Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
TOSHIBA TV- HCN4226W convergence PROBLEM
I want to buy this TV for $100. How expensive to fix convergence? Can I just replace a part? See advertisement below.
"42" toshiba cinema series tv (not HD, needs a fix with the convergence. Comes with stand and manual.
  • dawnavs Jan 02, 2009
    Thanks to this forum for some tips.
    If your Samsung HCN4226W is having blue shadow or radiant(double cross), first check your blue crt. The coolant could be Contaminated.
    I read thread in this forum and open mine toady. Instead of it being clear, it was milk or cloudy. I drained it but I bought the coolant online but hasn't arrived.
    If you have similar, I can give you tip on how to take the CRT out rather then messing with the YOKE.
  • dawnavs Jan 03, 2009
    Thanks Ladywinn. I meant to post that. You're a veteran. I might get my Hi Def cable from you once this thing works. Your website pricing is great. Are those new or used items?
  • Samsung Master
  • 5,138 Answers
I charge 285.00 at my shop ,so if you cannot fix it your self you are looking at repair anywhere from that price or more .You have 2 STK ics these are your convergence Chips .You would need to replace both of them.If you can solder you have it made.
Posted on Dec 20, 2008
  • ladywinn
    ladywinn Jan 02, 2009
    Parts www.matelectronics.com or 1-800-628-1118 Thank you for coolant information But I have been doing this work everyday for 30yrs, so i pretty well know how to change fluid in Tubes ,There is alot of people who would love to have you post that information. I am Self-employed and own TV Repair Shop.
THe picture is either yellowish green or yellowish orange. And has squiggly lines thru the picture. What needs replaced?
Tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.Try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Samsung/Akai tvs using the same convergence board.
Nov 06, 2010 | Samsung HCN4226W 42" Rear Projection...
Picture has blue at the bottom and yellow at the top. Double images and the station logo is in the wrong place
This tv have convergence problems.Tries website Tvrepairworld.com to buy the whole refurbish convergence board for the replacement.The Samsung/Akai used the same convergence board.
May 15, 2010 | Samsung HCN4226W 42" Rear Projection...
I recently bought a samsung hcn4226w at a yard sale for $50. Thought it was a good deal, but when i got home I saw the picture had a double image and the picture doesn't seem bright. After some tinkering...
This tv have convergence problems.Ur tv convergence board the 2 STK convergence ICS are defective,and some or all it resistor are dead.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.Spend about $100 dollars more this tv can be save.
May 14, 2010 | Samsung HCN4226W 42" Rear Projection...
Hcn4226w tv blue convergence blury
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 10, 2010 | Samsung HCN4226W 42" Rear Projection...
Is $400.00 REASONABLE FOR REPAIRING A CONVERGENCE PROBLEM ON A sAMSUNG hcn4226w?
no it's not reasonable at all.if you are positive that it is a comvergence problem you can go to bestbuy and do a part search and get a complete convergence board for aroung $100 depending on where you live because of shipping. i live in ohio and i just replaced mine and it cost me $95.67 thats tax and shipping and was very easy to install about 10 minutes.
Aug 24, 2008 | Samsung HCN4226W 42" Rear Projection...
Blue ghost
Replace convergence IC'S and check values of convergence circuit resistors.
Aug 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Rear Projection TV
You can get the convergence board by clicking here.
The service manual you might buy it from the same place.
May 23, 2008 | Samsung HCN4226W 42" Rear Projection...
What is the convergance??
tv model is pt4298hd repair shop said that he replace both convergance chips check all res/caps all reading in spects.
Dec 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W Service Menu?? For convergence issue????
The resistors on the new module are not 100% Identical in resistance to the originals on your board, to access the svc menu you will want a service manual and will require some patience. It can be tricky I would personally call a repairman with convergence in mind. Or order a manual and read the conv section several times. http://www.eserviceinfo.com/index.php?what=search2 Is one site, might have to purchase one.
Jul 06, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergence problem?
That board, P/N Bp94-00155a should fix the problem and be fairly easy to replace. Make sure you unplug the TV before starting the repair though. Duh!
Mar 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Jerry Greenberg
Jerry Greenberg
