Question about Brother ML-100 Typewriter
We are having problems installing the correction tape for the Brother ML100
    Scholar:
  • 183 Answers
PUT THE SUPPLY SIDE ON FIRST ON THE LEFT SIDE OF THE PRINTHEAD. ABOVE THE TAPE AND RIGHT IN FRONT OF THE CARDHOLDER THE IS A GUIDE, TAKE THE TAPE AND TURN ITTO THE RIGHT AND PUT IT IN THIS GUIDE. THE DULL SIDE OF THE TAPE SHOULD BE AWAY FROM YOU. THEN PUT IT BETWEEN THE TWO METAL "FINGERS" AND THE CARDHOLDER AND THEN IN THE GUIDE ON THE RIGHT SIDE, THEN PUT THE TAKE UP SPOOL ON THE POST AND TURN ITT THE DIRECTION OF THE ARROW ON THE SPOOL UNTIL IT IS TIGHT AND THE "LEADER" IS PAST THE PRINTHAMMER
Posted on Dec 20, 2008
My typewriter will not type the correct letters I have replaced the wheel twice any suggestions?
Make sure that ps pitch is not selected. check if ribbon or corr. tape is in printwheel
Sep 26, 2014 | Brother ML100 Daisy Wheel Electronic...
I am having problems changing the correctable ribbon. It does not correct after installation.
if it prints but doesn't correct, it is probably a problem with the correction tape. make sure the tape is instaled in the correct postion with the dull side towards the paper
Mar 14, 2011 | Brother GX-6750 Typewriter
Brother ml100 standard - eraser tape will not erase, nor will it rotate to more tape. There is sufficient tape on the roll. Thank you
do you have it past the leader ( the red part)? there is a sticky place just before the actual corr. tape starts. you need to pull this loose before you put the tape on. it should turn counter clock wise. the tape should all be on the round spool, not the spool with the knob. if this info doesn't help - let me know. never seen the corr. tape stick so that you can't turn it by hand.
Dec 24, 2010 | Brother ML-100 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
Typewriter is an ML100 Standard Brothers Typewriter
repost if you are still having this problem
Aug 28, 2008 | Brother ML-100 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
INSTALLING CORRECTION TAPE ON A BROTHER SX4000 TYPEWRITER
I have a brother SX4000 at work and I am having a hard time getting the correction tape on. Can you help with any instructions?
Jan 29, 2008 | Brother SX-4000 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
252 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
