Question about Welbilt MR755T Microwave Oven
Microwave 800 watt WP800P20-3 Galanz
The micro-wave doesn.t work anymore.No heating ,nothing.
Where can I find the fuse?
with kind regard
m.m.schomakers
  • Anonymous Feb 04, 2009
    same problen lights and everything works but ho heating
MicrowaveSvc
  • 9098 Answers
SOURCE: Dandy Designer 800 Watt Microwave
I would suggest that you try it for a minute or so on the very lowest power level and see if it shuts off. If so, please post again with more detail about how it fails, such as whether it loses all power as if someone unplugged it or just acts as if someone hit the STOP button.
Posted on Apr 16, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: KitchenAid KHMS155L 1000 Watts
According to the owner's manual for model KHMS155L:
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound and a lock icon appears on the display. Repeat to unlock and remove the lock icon from display.
You can download the manual here:
http://www.kitchenaid.com/custserv/service.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I was given a Galanz
In your owner's manual, you should be able to find contact info for Galanz so they can arrange for repair. Hopefully it has a full year's warranty.
Otherwise, I would ask the person who gave it to you what dealer or store they purchased it from, and the store should have contact information for Galanz in your country.
Good luck.
Posted on Jul 06, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Galanz Microwave Oven - Unable to disable child lock
Galanz's website seems to be useless. I tried finding information but kept being told "no data available." So while I can't tell you where to find the manual, here's something to try. Most microwaves get put into lock by pressing and holding one of the buttons for longer than normal, or by pressing one of the buttons several times in a row. Some ovens use the TIMER button. It won't be one of the number keys, but one of the function buttons. So start with a button, press and hold it for at least 5 seconds before you let go. If nothing happens then try another button. If that doesn't solve the problem, then try pressing each function key several times before moving on to the next one. If that still doesn't get it going, maybe a store in your area that sells Galanz will take a look at the book for you. The process should be the same for any similar model.
Posted on Nov 11, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Where to purchase a new fuse for Galanz Microwave
20A ceramic fuses can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Feb 15, 2009
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
Micro wave not heating up
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 21, 2010 | GE XL1800 1100 Watts Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Micro wave not heating water
heatman101
Aug 02, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
The toaster on LG LMF-9030TW combined with micro-wave is not heating. The fuse is ok and wiring also. Cannot bring it to repair shop cause I will be out of micro-wave for 2-3 weeks, until fixed. Probably...
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Jul 07, 2008 | Microwave Ovens
I was given a Galanz Grill/Microwave Oven WD900A for my 54th birthday 24 jan 2008 it is July 2008 and the micro wave has lost its heat power.It saddens me that a real nice microwave only had a short...
Good luck.
Jul 05, 2008 | Microwave Ovens
Microwave Ovens Logo
228 people viewed this question
Top Welbilt Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Welbilt Microwave Oven Expert? Answer questions, earn points and help others
