Question about Lufkin Measuring Tools & Sensors
Measuring tape won't retract or advance
Lufkin 50 Chrome clad HC253
    Scholar:
  • 35 Answers
If it has gotten wet, muddy, or sand and grit in it you can spray WD40 in it and slowly move it in and out cleaning it as you go. do not pull it out to far ( no more than 6 inches past 49 1/2 feet. If ytou pull out a tape measure to far it will uncoil the spring and you will either need a replacement refill or just get rid of it and ask Santa for a new one. I have used broken tape blades for "measuring sticks". Simply cut them into 1 or 2 foot sections for hard to reach areas.....Joe
Posted on Dec 21, 2008
Here are some tips for maintaining a functional tape measure: The right lubricant applied to the blade will often help one that is recoiling poorly. Wd-40 will cause the print on stanley tape measures to peel away. I'm not sure of other brands. Neumatic tool oil seems to be an ideal lubricant, but vegetable oil isn't as it seems to break down very quickly. Don't pull your tape measure out so far that it gets too close to it's maximum length. I've had them break at 6" to 10" short of their "maximum" lenght. If it didn't break when pulled out too far, it's possible that the recoil mechanism was locked up. If it is locked up while nearly fully extended, pull it out just an inch or so more and then release. It seems the recoil mechanism can get hung up when the tape is nearly fully extended. You'll notice it's tense and not pulling out as easily as you think it should. Keep trying until it coils back up, each time pulling it out just a little further If it's locked up while nearly fully extended it's probably about to break so be careful and don't pull it out too far or too hard. When it releases there will likely be a lot of recoil sending the tape coiling back into it's housing very quickly. Be careful not to have your fingers near the tract opening unless you don't mind getting cut. If the recoil doesn't kick it out of your hand, it's probably best just to intentionally let go of it and drop it to the ground where it will continue to coil up all on it's own. Keep in mind the problem could be sawdust etc. build up in the lever lock mechanism that is preventing it from fully unlocking. Your tape measure may appear to be unlocked yet the blade is still stiff. You can also try moving the lever lock back and forth a few times and a dripping a few drops of oil into the lock might both help. If the tape is just sticking lightly or gets stiff on the recoil several feet out or so you can try extending the blade out and then lock it so it stays out hands free. Now you can put a couple drops of oil on it every few feet along the blade. I prefer to wipe the oil down the blade running it between my fingers (carefully so not to get cut) so it doesn't take so long to spread around by itself or too unevenly (don't use too much oil where it's dripping around on the blade). This is also a good way to clean any grime off the blade helping it to recoil smoothly. Water isn't ideal to clean the blade unless you're prepared to dry it off. Small scratches in the blade coating where metal is exposed will rust and become weak points where the blade will eventually break. If grime doesn't appear to be an issue simply try pulling the blade out a good distance past the point on the blade where it likes to slow down or stop recoiling, then just let it recoil. It seems sometimes the blade doesn't coil up tightly after making lots of short distance measurements and this is a quick fix for that. Happy measuring.
Posted on Mar 29, 2014
Repair lufkin measure tape
Asking Lufkin is your best option as they might repair or replace for free or low cost.
The Official Site of Lufkin Brand Measuring Products
There are videos out there that will show how to take tape measures apart. However it can be tricky and if you are not careful the whole thing can become a mess to deal with. Most companies will not offer repair or replacement if you have tried to fix it yourself.
May 05, 2015 | Lufkin Measuring Tools & Sensors
Tip
How clean your Ford Edge chrome clad wheels so they balance
The Ford Edge chrome clad wheels are causing balancing issues and costing everyone money in unbalanced and prematurely worn tires or even wrongly thinking the tire is bad. Watch this video and discover how the chrome clad wheels can be cleaned and balanced.
Are your Ford Edge Chrome Clad wheels costing you money
on Mar 28, 2016 | Ford Cars & Trucks
I purchase a Lufkin tape measure and now the tape will only extend out 18" and no further. I have checked and the "lock" button is not on. How do I go about getting this replaced? I use this tape...
When you pull it out eightteen inches, does it feel like it's under tension like normal? Is it retracting like normal? If so pull it out hard, in a quick tug, you probably got something in it. It's just bound.
Sep 18, 2013 | Hand Tools
I dont know what it measures by? my dad bought a lufkin 100' 1706 and he is trying to figure out how to use it because the measurements seem to be off. for example he compares it to other measuring...
Hi...sorry for the bad image but if you can make it out ...this tape measure is offered in two types of measurements either Feet/Inches/Eighths or Tenths/Hundredths ...if your father's is off by an inch my guess is that the Lufkin is measuring in Tenths/Hundredths.
Hope this helped!
Here is a better look: http://www.cspforestry.com/Lufkin_1_2_x_100_Hi_Viz_Orange_Fiberglass_Tape_p/lufkin1706.htm
Sep 18, 2011 | Lufkin 1706 100' Fiberglass Tape
How to replace a lufkin tape
are you looking to replace the tape blade, or purchase a new tape measure all together ?
Mar 11, 2011 | Garden
Tape broke on W928 tape measure
I looked around and can't find a replacement tape for this 12 footer. The tape measure itself seems to be no longer available.
I suggest recycling it and buying a new tape measure.
Jan 06, 2011 | Lufkin 8ftx1/2in Tape Rule W928
I pulled my Lufkin luorolok tape out the whole way and now it won't retract - Help!?!
You need to take the screws out of the side but you may have broken the spring recoil mechinasum you can get a new tape but if the recoil is damaged its not worth fixing it would coast you more then buying a new one
Dec 07, 2010 | Lufkin & Hi Viz Tape Rule
How do you fix a broken tape and what size "rivits" to repair a 100' 1/4" tape
pick up and throw out. purchase new one. If the tape head or foot. (End grabby bit) has broken or moved to far the tape will not read accurate. So if youre using a tape that has to be calibrated or has to be accurate its useless.
hope it helps.
Oct 03, 2009 | Lufkin Measuring Tools & Sensors
Measuring Tools & Sensors Logo
2,373 people viewed this question
Top Lufkin Measuring Tools & Sensors Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Lufkin Measuring Tool and Sensor Expert? Answer questions, earn points and help others
