Question about Aiptek A-HD 720P Flash Media Camcorder
Putting video files to hard drive
Can i transfer files from camcorder to hard drive so that i can copt to disc? camcorder has usb, recorder has dv socket
  • 2,794 Answers
You should be able to transfer files to the hard drive. The camera will be assigned a letter in my computer. Divx software is good to convert them onto a disk and it's reasonably priced.
Check it out at www.divx.com
Posted on Dec 17, 2008
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
How to transfer record to my laptopeduard
needs drivers to install camera to laptop. or In order to place taped videos to the PC, you need a Fire Wire port on your computer, a 6pin to 4pin fire wire cable, and a lot of hard drive space. One hour is about 14 gigs when transfered 100% uncompressed. After editing and compression though the file size is very manageable.
**For every minute you record it takes one minute to transfer to the PC*
or you need a usb videop capture to transfer video to your laptop
Sep 04, 2010 | JVC GR-D850 Mini DV Camcorder
Can not get video files from a mini dis dcr dvd 108 handycam when I try to import to my pc it says does not support this dis i was using usb cable to pc with sony's software thanks jim
First make sure to finalize recorded disc in camcorder, finalization option is available in camcorder menu and will be enable by powering camcorder with AC charger/ adapter.
Now you can transfer movie files in computer or put recorded disc in computer dvd rom and copy files.
Jul 31, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
How to transfer video from camcorder to pc bcoz i have image mixer installed it is not happening dcrdvd201 it says usb driver does not support this version window vista home premium what do i do
There is no need to hook camcorder with computer through USB, all is required to Finalize recorded DVD in camcorder and put that disc in computer to copy files for further editing etc.
Finalized disc in camcorder will be recognized in any other dvd player or dvd-rom.
Finalize disc option is available in camcorder menu.
Thanks.
Feb 05, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Transfer from pz card shot on HD to mini DV tape
you can transfer to DV tape only by using software like Edius 6 or a similar one.
First you download the p2 card on the hard drive and then you use this program to convert the video file to DV and use the camcorder as recorder connecting to pc via firewire .
Jan 22, 2010 | Panasonic AG-HVX200A Mini DV Camcorder
Hi am wanting to put some footage from panasonic sdr h40 onto computer
Your Panasonic camera has a USB port on it as associated by the accompanying cable that plugs into it and has a USB end on the other cable. Note that if your videos are on the SD card, you can take it out and put in your computer via a SD adaptor to USB. The hard drive files though are a little more tricky... you have to have the camera being fed by the AC adaptor instead of the battery.. (it looks like the battery and plugs into its hole on the bottom with a cable hangiong out that plugs into the battery charger.. You will not be able to transfer the files unless you have this power configuration.. this is to keep the transfer from being disrupted by running out of battery power. The files are MOD files which are MPEG2 files just renemed. You can rename them to MPG instead of MOD once you copy to the computer. The USB connection forces the PC to make a drive letter for the hard drive in the camera. I hope that helps out
Than ks!
STan Skaggs
Oct 29, 2009 | Panasonic SDR-H40 HDD Camcorder
Completly confused
You need a video recorder program. The SC-D23 is a MiniDV tape camcorder, not a hard drive based camcorder. So you can't just drag-and-drop, it doesn't show up as a drive.
And you must use the Firewire cable. The USB connection is only good for transferring from the memory card.
Windows Movie Maker is free and can transfer from a Firewire drive like this one. If you don't have it already, download WMM from Microsoft's website. The Help files should tell you all you need to know, if you need to know more about using WMM you can come back here and post in the appropriate area.
Whatever video recording program you use, it will run the camcorder as if it were a VCR that you were recording from.
BTW, it is very important that the camcorder be turned OFF when you plug in the Firewire cables. Turn it on only AFTER it is connected to the computer. Otherwise you may destroy the Firewire port on the camcorder.
Mar 25, 2009 | Samsung SC-D23 Mini DV Digital Camcorder
How to convert dv tape from Canon ZR20 to MY COMPUTER hard drive?
To transfer video off your minidv cassettes from your camcorder you would need to have a firewire connection to your PC. Either a 4 to 4 pin connection (laptop) or a 4 to 6 pin (desk top computer). USB is used only for picture still transfer. Here are the steps;
1. Plug your mini Dv camcorder into an outlet
2. Plug in you firewire connection into your computer, then plug the other end into your camcorder.
3. Turn on your camcorder and switch your camcorder to Play/VCR
4. Select the software that you want use to do the transfer. Windows Movie Maker is the most assessable software since you have XP on your computer
5. Name your file
6. Select capture from video device (automatically will allow you to save the entire tape and manually would allow you to capture parts of the tape).
Those are the basic steps in some detail. You can save your file from there or you can go on to edit.
Jan 02, 2009 | Canon ZR20 Mini DV Digital Camcorder
Transfering from a hard drive camcorder to a mini dv
Yes. Using a DV or firewire cable and the right software you can record to DV tape. I know Pinnacle Studio software is capable of doing this and will even control the recording of the taping as well through the sofware.
Nov 20, 2008 | Canon ZR70MC Mini DV Digital Camcorder
Transfer my minidv camcorder film onto DVD
You need to download the movie to a computer and store it in a video file. Then you should be able to use a software program to burn it to a DVD. I use a TIVO for watching and burning my videos. You don't need a computer. You save the video by recording it to the TIVO's hard drive then after it is on the drive you DUB it to an empty DVD-R disc.
Jan 24, 2008 | Panasonic NV-GS17 Mini DV Digital...
Aiptek A-HD 720P Flash Media Camcorder Logo
98 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
Michael Galve
Michael Galve
Jose Ma DM.
Jose Ma DM.
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
