Question about Sony Handycam DCR-TRV525 Digital Camcorder
No Color now -- Sony HANDCAM CCD-TRV40
Sony HANDCAM CCD-TRV40 -- I'm getting no color in the recording or the playback. I did the cassette door problem fixed ... just some moisture, I guess. But now there is NO COLOR at all in either the recording or the playback (playbacks previously were already in color!)
SOURCE: Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Posted on Jun 09, 2007
SOURCE: Cassette load issue
reel table on the right ( take - up ) if has low tension ? will slow down or stop , giving reinsert error : stretching spring ( inside reel table ) will fix problem , as well as to order and replace reel table .
Posted on Aug 08, 2007
SOURCE: camcorder
lcd screen blank
Posted on Feb 08, 2008
  • 4402 Answers
SOURCE: cassette loading error 31:23
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Feb 22, 2008
I have had this same problem several times. In all cases the problem has been a tape that has been run at the very end of it's lenght and it is too tighten. I loose the tape manually just a bit and it helps. Just be careful not to leave the tape too loose.
For loosing the tape you have to push the lock button with e.g. a pen and while doing that just take the tape out just a bit. Tape should be left at the level it was. It must not look like a loosen tape. If you get it out too much, just roll it back by twisting the reel again while pushing the lock button down.
To be able to loose the tape you of course need to open the protective lid first. For this there is a separate lock switch at the side of the cassette.
Posted on Mar 05, 2008
  • 10594 Answers
SOURCE: No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Posted on Jun 18, 2008
0 characters
1 Points
After 90 minutes or so of perfect play back... the picture became very distorted (static) and lost the sound completely. I manually cleaned the head. Distortion is less, sound still out.
please try to clean the cassette tap running path like capstan motor shaft and the inclined posts and the pressure roller Etc, check the roller for loose if any.
Feb 18, 2016 | Sony Handycam CCD-TRV40 Camcorder
My sony Handycam video 8 ccd-trv40 will no longer record any sound. The camera will play back older tapes and their audio and video. Any suggestions?
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Sep 21, 2010 | Sony Handycam CCD-TRV40 Camcorder
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
May 10, 2009 | Sony Handycam CCD-TRV58 Camcorder
Jan 15, 2008 | Sony Handycam CCD-TRV40 Camcorder
Play back problem
Your camera playback heads appear to be dirty. You can purchase a head cleaner cassette from an electronics store or take it to a service centre where they will clean the heads.
Check that the tape itself is not damaged, as this can cause the same symptoms.
Jan 03, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Trouble with camcorder
try cleaning the rubber pinch roller with a cotton swab dipped in alcohol
May 26, 2007 | Sony CCD-TRV238 Camcorder
Partial static in playback and record even after head cleaning
Replacing the cylinder with video heads part number A7048897A will cure the problem. If you need more help please advice. Arpi
Mar 16, 2007 | Sony Handycam CCD-TR517 Camcorder
Sony Handycam DCR-TRV525 Digital Camcorder Logo
24 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
