Question about Minolta EP1030/1030F CS/PRO Copier
Minolta Di550 error code C-0500
We moved the copier to another office and when we turned it on we got error code C-0500
  • mmrules Dec 17, 2008
    Worked great. Thanks.
    President:
  • Minolta Master
  • 990 Answers
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Posted on Dec 17, 2008
Di 450
replace the print head, print head houses the LASER for the machine, might try this site as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 02, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Konica minolta is not switching on
Open a front door and remove a fusing unit and turn ON the copier.If the copier turn on and appear on error code to refer a fusing unit a problem in the fusing unit.
Dec 16, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di550 error code c-13fc
Image processing board or the Print head ( What houses the LASER inside the machine they are not talking to each other so that code is displayed. Check the connections , I would go with print head 1st. Di550 is a legacy Minolta machine, might be tuff finding a print head as for Image control board WOW! Home and close front door resets if it comes back need above
Nov 19, 2013 | Minolta Office Equipment & Supplies
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Minolta Di550 Copier with a malfunction code of C-OF24
Hello sir; here have few steps need to follow;
1, press "function", press "printer", "F8" press "start" machine will run about 4 minutes the start key will turn from orange to green.
2, same procedure go to F5 will run about 30 seconds.
Jan 08, 2009 | Minolta EP1030/1030F CS/PRO Copier
508 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
