I cannot receive the network on my home docking station, if I hold the leads into the terminals on the station, I pick up the signal. When I release the tension, the signal drops off again, and reception never returns. I loaded the radio, an ST4(A) back into the docking station in my vehicle yesterday and only get an antenna not detected signal, I cannot gain reception. I checked on the roof of my vehicle as it snowed, I wanted to see if the antenna was covered with snow, it was not. I'm becoming very frustrated, I am also a long time customer, I hope someone can tell me what to do, either return the radio and docking stations, or wait for a no charge replacement on all of the above. I will wait for your response. My account # is, 3805168285, the radio has and SID # of 022253922556, the fcc id # is NKRUPAST410, once again a model ST4(A) I am also an artist and work out of my home, which means I normally listen to the network through the day. Thank you, I will wait for your response. Bob Koser
  • 21 Answers
SOURCE: Radio stations have shushing sound
Cheap table top radio is mono. Your Denon is not getting a good signal so you are hearing noise. You need a better antenna (roof type) or the antenna needs to be moved and aimed in another direction. Try moving it while the station is tuned. You can also switch the Denon to mono and it will reduce the noise at the loss of fidelity.
Posted on Sep 03, 2007
SOURCE: no antenna detected
Where Can I purchase a new XTR1 satellite radio?
Posted on Aug 22, 2008
SOURCE: sirius sportster sp-tk1, always displays "acquiring signal"
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Posted on Aug 31, 2008
SOURCE: Insignia® - 75W DVD/CD/HD Radio
Connecting an external AM antenna solved the problem. The internal antenna (if there is one) is useless.
Posted on Sep 09, 2008
  • 193 Answers
SOURCE: Charging Light On After Replacing Alternator/Battery1999Windstar
Hi, I can't tell you exactly what is wrong because there is too much involved at this point, what with 2 shops working with it, but I can give you some advise on what else to check. On the alternators and the wiring that supports them a small volt charge is taken off one of the slip rings, where the brushes ride, for the purpose of turning out the light. As I remember, this is a yellow wire that runs back to the dash.
To the alternator, it would be one of the wires that plug into the side of the alternator case.
jetski
Posted on Nov 27, 2008
I can receive FM stations properly. I cannot receive AM stations at all. Only a static sound. I disconnected the AM antenna leads and used an Ohm Meter. The meter read full continuity when I touched...
you may be in an area where am stations don't come in,, am uses straight lines of frequency where FM uses a modulated signal, which travels much farther, I bought a antenna signal booster from radio shack for a few dollars , and was able to get the stations, some pretty static filled though, but the more local ones came in ok, another thing to check is that the unit is plugged into a grounded receptacle ,
Sep 10, 2011 | RCA RTD217 Theater System
It will not hold the signal as long as it used to.
I would try cleaning both the dock and the receiver pin connectors with alcohol, then drying and try that.
Jan 01, 2010 | Sirius Satellite Radio Sirius Sportster...
I have a Dell Latitude D610. At home, myy wi-fi signal typically runs at 48-54 Mbps and signal strength reads as "very good". When I drop my notebook into a D-family docking station (plugged in peripherals...
no
but may as you know that the anttena for wi fi in the laptops located in the side of monitor so it is polarization issue sure when you open the laptop screen it will be different when you close it to put it inside the docking station>>>to solve this you can change the direction of your router anttena
wish that will be helpfull
shadi
Nov 21, 2009 | Dell D/Dock Expansion Station Docking...
Hook up dell laptop to docking station: I have a dell lap top inspiron 1721 and a dell model # PRO1X docking station, I would like to hook it up in my home office. I have never done this before and just...
this is easier than you think my friend, firstly put the dock on your desk, plug in power lead, network cable and monitor cable, place laptop on dock (making sure it clicks into place) turn on dock and monitor and your up and running
Oct 16, 2009 | Dell Inspiron 1721 Notebook
No signal
Here is a site that cares a lot of sat. radio things
http://www.xm-radio-satellite.com/
This maybe what you are looking for a "Delphi XM Radio Wireless Signal Repeater System"
May 08, 2009 | Delphi SKYFi XM Radio Receiver
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
Audio stuck on high
You cannot adjust the volume when the stereo cord is plugged into the back of the dock. Instead, plug the stereo cord into the front headphone jack of the dock. You will be able to adjust the volume then.
Mar 11, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Connecting iPod Docking Station to Video 4
On your iPod, go to Videos, Settings, and set it to TV out. Make sure the TV Signal is set to NSTC.
Jan 19, 2008 | Onkyo TX-DS787 Receiver
41 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
