I am trying to install a 3rd monitor with a VGA to USB cable. The users guide says it wont work with a Standard VGA Graphics Adapter driver. I do not know what that is.
Unfortunatly the only whay a 3rd monitor is possiable is with a video card the supports it, unless you use a usb monitor like a lilyput you get those a www.thinkgeek.com.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: i have just reinstalled windows vista on my
If you do not have the cd for the drivers you need to download the drivers on a flash drive or if you have the provision to download and burn them on CD download all the drivers on the link given below and you will be able to resolve the issue install the chipset drivers first then any of the other drivers
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
SOURCE: display adapter
You will have to get a "Driver" for your Video Adapter. This WILL be a problem as there probably isn't one.
There may be one shot, try this.
Download your Video Adapter's XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop.
You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP.
Right click the .exe file and select "Properties".
Then select the tab called "Compatibility"
Now check the box next to "Run this program in compatibility mode for:"
Make sure "Windows XP Service Pack 2" is highlighted.
Now apply the settings and run the installer.
This should work for most drivers, but not all
The drivers are here INTEL, right at the bottom.http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_P4_1150&hidos=WLH&hidlang=en&TabIndex=
Thank you for your answers. What I meant was I do not understand what a Standard VGA Graphics Adapter driver is. I got brave and installed the software that came with the usb to VGA cable. It seems to be working (yaay) although it is very slow. I do not know if there is something else I need to do to make it run faster.
