Question about Alpine DDW-F30A Car Speaker
1999 Audi A4 Rear Speakers
I'm putting in new rear speakers. I have taken out the rear seat backsand popped off the shelf. Then I placed in the new brackets to allow me to fit universalspeakers and screwed in the speakers (to the brackets). However theleft rear speaker has a large connector block which i have never seenbefore with about 6-8 wires attached to it. This will not fit the newspeakers (they only require 2 wires). However the rear right side does fit the car as it only has 2 wires. How can i fitthe left side to the speakers? P.S i also hav a new head unit
  • samaan_uk Dec 18, 2008
    Thanks very much man! Your a saviour!
  • 1,586 Answers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Posted on Dec 17, 2008
  • Jeremy Dellow
    Jeremy Dellow Dec 18, 2008
    Heheh, glad it helps. Don't hesitate to reply here with any additional questions as they arise:)
1999 Chrysler Concorde LXI Rear Speaker replacement
If you mean the rear shelf removal, then you begin by removing the rear seat (lift to release the corner clips on each side holding the cushion to the floor). Then remove the fasteners for the seat belts, then lift the seat back to raise and release it from its clips, and remove it from the vehicle. There are then a lower and upper trim panel around the back shelf that you need to remove (these may be on each side of the shelf, e.g. they are called 'quarter trim' panels). Then you will see some push-pin fasteners that hold the shelf across the front lower edge, so you gently pry out the center push-pin of each one of those to release the fastener. Then you pull the shelf forward to release it from the clips that hold it under the window. Then remove the wire to the center high-mounted brake light. The panel with its speakers attached can then be removed, but also remove the wires from the speakers so you don't break those. connections.
That is the procedure as shown in my '98 manual.
Mar 31, 2010 | 1999 Chrysler Concorde
99 A6 Subwoofer and Amplifier
I have a similar problem on Audi A6 2.5 tdi year 2000, is just that my subwoofer is working fine, but the rear speakers have no sound and the rear satellites on the same ciruits are working just fine, I cannot explain this! I have taken apart the rear speaker and teasted with an ipod and one is working fine but the other is dead! I don t know if there is any connection, or there is a filter for the rear speakers and if one speaker is dead there will be no sound on the other speaker! but as i said on the same cables satelites are working well!
Mar 16, 2010 | 1999 Audi A6
Retro fitted radio
i believe that car has a pre-amp in the rear speaker setup, but the clip should work fine, i would return it, they do have a 10 percent failure rate. Nothings wrong, there's just a lack of signal. If nothing else works you may have to run speaker wire from the deck to the rear. Its not bad, just takes some time and common sense, as long as you are comfortable doing that stuff, most of the platsic around where your doors go is simply clipped into place, and can be removed and replaced with relative ease, run the wires for both spkrs on the same side, get them in the trunk, and hook them direct to the speakers themselves. Good luck!
Aug 18, 2009 | 2000 Audi A4
1999 audi a4 rear speakers don't work
There is an internal amp connected to to lft back speaker that you woill need to by-pass
Jul 05, 2009 | 1999 Audi A4
Rear speakers audi a4
look at crutchfield.com for free, they should be able to answer you're question...
Good Luck
Jun 14, 2009 | 1999 Audi A4
Need rear speakers for 1999 audi a4
Car toys. or the dealership..
Apr 01, 2009 | Car Audio & Video
1999 intrigue rear speaker help
The lower seat cushion, the back seat rest, the side trim panels and the package shelf all have to be removed to access the rear speakers.
Mar 06, 2009 | 1999 Oldsmobile Intrigue
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
1998 Audi A4 Quattro rear speaker wiring
You can't use any of those - the large connector at the OEM speakers is because the rears are amplified. Your factory head unit puts out a line level signal to the rear speakers. There's an amplifier on the driver's side rear speaker (the box around the magnet that you can see from inside the trunk).
You need to either replace the head unit with an aftermarket one to drive your new speakers, or you need to tap into the amp connector and find the line level wires, break them out, put RCA plugs onto them, and plug them into an aftermarket amp, which you'd use to power your rear speakers. Doing it that way allows you to keep the factory head unit.
Oct 25, 2008 | 1999 Audi A4
Changing Rear Speakers in a 1996 a4.
First remove the rear seat bottom cushion (grab the front edge roughly in the center of each seat position and pull up firmly, and it'll unclip and come out). Then fold down the rear seatbacks. Now, the side bolsters for the seats (between the seatbacks and the doors) have to come off. First, pull down strongly near the bottom (there's an upward-facing hook there that clips onto a ring and holds the bottom in place). Pull down and forward and it'll come off. Then slide your hand about 75% of the way up, and pop the bolster straight forward to pop out a retaining clip. Finally, you can remove the top of it from its mount, and you'll have the bolster out. Repeat for the other side.
Go into the trunk and look up at the bottom of the rear shelf. The harness plug for the third brake light is there - unplug it.
Now, back in the rear seat area, just grab the front edge of the parcel shelf and lift upward to pop it loose, and the whole thing will slide forward. Then you can remove your speakers.
Install is the reverse of disassembly.
Jul 30, 2008 | 1996 Audi A4
Alpine DDW-F30A Car Speaker Logo
291 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
