Question about Kenmore 63942 Dryer
Dryer not running properly
The dryer only runs when the start button is pushed.  Once you let go of the start button it stops.
  • Kenmore Master
  • 8,220 Answers
The run winding in the motor is shot. Time to replace the motor.
Posted on Dec 18, 2008
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer requires start button to be depress constantly for dryer to operate
If I am not mistaken, once the timer is set and the button pushed, the motor should run and there is probably a contact in the cintrifugal switch of the motor to seal in the run circuit. On a working dryer, if you push the start button for a split second, and let go the dryer will stop. This is because the motor has not reached proper rpm and the switch is not made yet. If the switch hangs up or the switch goes bad the same symptom will occur.
Aug 30, 2011 | Roper Dryers
I have a kenmore he3 dryer that won't stay on. When I push the start button, the motor will turn the drum about a quarter of an inch then stop. I then need to push the pause/cancel button once and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 16, 2011 | Dryers
Push the start button and the dryer starts & once the button is released the dryer stops.
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 19, 2010 | Dryers
Hi my dryer buttons seem all good but as soon as i start the spin it spins for a second then stops then it beeps repeatedly
Whats brand dryer is it? Older style or newer style. Is it the regular machanical timer style dryer or the new computer led light style dryer? If it the regular machanical timer style type, then you saying when you push the start button it starts but once you let go of the "push to start" button it stops. Is this right? In that case is could be a bad motor. The centrifigal switch in the motor is probably bad and isnt holding to the "run winding" in the motor internally.
Jul 30, 2009 | Dryers
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Dryer won't run. Stops after 30secs
Sounds like the timer is going bad and it needs to be replaced. The time is located behind the knobs.
IF my answer has satisfied you please rate. Thank you
Feb 11, 2009 | Amana ALG331RAW Gas Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
