Usb ports not working on nec i-select m5210 laptop?
I have a nec i-select m5210 laptop and none of the USB ports are working.
If I plug a device in to them the power comes back and lights up the external hard drive but the laptop doesn't reconize the device that is plugged in.
Could this be the controller on the motherboard or is it something easy?
Usb device not recognized
Usually this means the computer saw that something was plugged into the USB port, but it doesn't know what device it is. It will require device drivers from NEC to recognize the drive. If your drive came with a driver CD, install these drivers. If the drive was working before, but now it's not, reinstall the drivers. If this does not fix the problem, then most likely either your drive is bad, or else your registry has become corrupted. Try another USB drive and see if your USB port is working, that is another possibility.
Oct 01, 2013 | NEC Computers & Internet
Nec i select m5210 upgraded to windows 7 i need a video controller diver that is compatible
just download this software,no need search engine,no more tired of looking anywhere...instantly,it will be in your laptop for several minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
Jun 06, 2011 | Computers & Internet
I have a nec i-select m5210.i dont know if the battery is dead or the laptop wont recognise it.if it is dead what is the no. of the battery i need
you can go on ebay and get a battery for an nec m5410, they are the same
Does the battery in an nec m5410 work in a nec 5210? I have an nec m5210 computer and need a battery, it looks like BATTERY FOR THE M5410 may work but i want to certain before i order from ebay HELP!!!!!!!!!!
  • 1 month ago
Report Abuse
1rvtbxww4aaeb_mhf9vk=.medium.jpg by DavidG Member since:07 June 2008Total points:15365 (Level 6) Best Answer - Chosen by Asker Yes they are the same - the part codes SQU-510 and SQU-527 are compatible
  • 1 month ago
Feb 17, 2010 | Computers & Internet
My magic jack is not being read by my acer notebook
when you plug it in does anything come up? If not then go ahead and try different usb ports and see if its read by any of them. If none of your USB ports read the magic jack and you know the USB ports work cause you can hook other devices to them then that means the magic jack is bad and would need to be replaced.
If none of your usb ports are reading any devices then that means the motherboard is bad at that point.
Aug 06, 2009 | Acer Aspire 3680 Laptop
USB PORTS
does your usb mem stick have any light indicators? if yes , whenever you put you usb stick, does it light? if it lights are USB ports is still ok,  You just have to reformat or partition you USB stick.
(you can also try other devices like usb mouse or any usb devices that lights up when you connect it)
if there are no lights if you plug, or no indication that a power goes to your stick, its possible that your usb your are busted. if this is the case, if your laptop has a PCMIA slot, you can find a pcmia USB card, if you dont have. your only option is replace the  motherboard.
Feb 01, 2009 | Averatec 3200 Notebook
Device drivers for Nec i-select M5210
go to microsoft.com and enter your vista model no(i.e)that is the no you mentioned(nec i-select)......you will definitely find the required drivers in that site.[but please enter enter your no correctly...otherwise you will find different drivers...].Try this it will work 100% for you.
Sep 18, 2008 | Microsoft Windows Vista Ultimate Edition
Problem plugging adaptor into cardbus usb port
sounds like its not supported by the NEC Cardbus
Feb 21, 2008 | Computers & Internet
Usb
there is a special card for this. It is a PCMCIA card that plugs into the PCMCIA slot and provides a USB port, available far and wide. search ebay's site for a new one at a very cheap cost.
Sep 08, 2007 | NEC Versa FX Notebook
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
