Question about Dell E173FP 17" LCD Monitor
Dell LCD monitor flashes white every second, and then goes black
Hi, My dell LCD 17" monitor flashes white every second, and then goes black. The green LED also flashes orange. The only way I was able to make it temporairily stop was by giving it a good smack on the back of the monitor. Initially, it would only occur when the computer went into sleep mode, and then trying to come back, this would occur. As time passed, the flahing got worse to the point where every five minutes this would occur. I broke down and got a new one (the warrenty expired about 2 months before), but I would like to fix the monitor if at all possible without having to spend a lot of money. However, I do not know where to begin. I have it apart, but cant find any obvious problems. Hope someone can help!! Thanks in advance. Mike
  • 1 more comment
  • ifineedit Aug 19, 2008
    My Dell E173FP 17" LCD monitor looks great when it starts up. After less than 5 minutes, parts of the screen begin to flash white. Then, within the next 10 minutes the flashing areas expand and flash more frequently, so that eventually the entire screen is white and no longer shows any other color. If I turn the screen off for a couple minutes, it looks great when I turn it on again. But then warms up quickly and begin flashing again. Thinking that some component is overheating, I removed the plastic casing and tried dust-spraying the various components inside, to see if I could cool anything and see if it made any difference in the performance of the screen. No luck. YET. I am concerned about removing the circuit board from the screen part, as it seems there may be some sort of anti-static strips between them, and I don't know how important they are for the short term.
    Has anyone been able to resolve a problem like this?
  • Anonymous Jan 03, 2009
    My dell monitor flashes on and off, power light is orange and is blinking also, after a few minutes I´ll move the power cord and the dell screen will show up and all is back to normal. Why is this happening?
  • banot Jan 21, 2009
    Its a nice solution, but i don't know how to open the panel.
    please help. If there is a procedure please e-mail me. thanks.. in advance.
Take a very good look at the power supply capacitors. Are any of the tops of the electrolytic capacitors domed? If you replace them, use a high frequency high temprature replacement to prevent a repeat failure. Don't use a standard 85 degree cap. It won't last.
Posted on Jul 24, 2007
Buy a new one PLEASE, HD monitor works best but the least expensive ones are smaller
Posted on May 17, 2007
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor Flashes On and Off
if may be that the inverter board at the back of the screen may be bad and needs replacement
Jul 12, 2008 | Dell E173FP 17" LCD Monitor
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD goes black after 2 or 3 seconds
Did you check CCFL lamps inside yet? If not, you should do that as well.
Mar 25, 2008 | Dell E173FP 17" LCD Monitor
Dell e171fp + turn off after a second
hi, are you able to browse thru the LCD menu, there must be some settings for power management.. let me know?
bye
Dec 15, 2007 | Dell E171FP 17" Flat Panel LCD Monitor
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
1,389 people viewed this question
Clive
Clive
Alun Cox
