I just bought a used Luxaire high efficency furnace for my garage model number PBNU-LD20N100D. The problem the previous owner said was the blower fan kept coming on every 20 minutes. He had a new circuit board installed for reeson unknown to me. I installed the furnace and noticed the blower starts running 22 seconds after the burners start up which is normal I've read for the honeywell fan limit controls. My biggest complaint is the blower fan won't kick off at the 90 deg. which is what I have the OFF set at. It will continue blowing to 55 deg. or lower. (this temperature I'm reading off the fan limit dial). I bought a new honeywell fan limit switch and still having the same problem. Any help would be greatly appreciated.
Comments:
Jan 02, 2009
- I replaced it with the same length fan limit switch.
I have one humidistat honeywell H8908B which presently controlls honeywell humidifiers(HE440A ). I...
(More)
I have one humidistat honeywell H8908B which presently controlls honeywell humidifiers(HE440A ). I am adding the HM512 onto the second furnace and trying to wire into the exisiting 440a. the 440a presently controlls both furnaces and works ok. can i wire and make the HM512 a slave ? and it still has to fill up with water an shut off by itself. i want both to act as one,but having the 440A keep controll of the fans. the service tech added a seperate two pole relay and spiced into to blue wire on the 440 and one side of the humidistat conector. also he set the number 4 dip switch on. this wiring left me with a over heating 512, it was super hotn to touch on the outside of the unit eventhough the main 440A was off.please help
I am getting six blinks on the call for service light after I push the reset button.What does that...
(More)
I am getting six blinks on the call for service light after I push the reset button.What does that mean?
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate...
(More)
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery notification?
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same...
(More)
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same message- replaced AAAs again, with what are absolutley fresh ones, same msg. Is there a backup batter somewhere on this unit that needs replaced? The manual does not indicate or show or mention a backup battery...stumped, 'HEP! thx, ed zeppelin the temperature guy
