Question about Gateway MT3705 Notebook
No sound, cant play music cd
Have a Gateway Mt3707 with vista. Haven't had sound for awhile and now I can't play a music cd, it just keeps asking to put a disc in the drive
  • Anonymous Feb 25, 2009
    no sound in XP OS, try anything i know.
Windows vista wont let me select subwoofer
Try Control Panel > Sound and Audio Devices > Volume > Speaker Settings > Advance. Choose Speaker setup.
Aug 27, 2012 | Gateway GMAX 2100 Computer Speakers
Two problems: 1. All the CD music I burn do not play in my car's and home stereo. 2. My computer is getting slow in opening programs and files.
are you burning the music cd's in the music format to be converted over and finalize the disk? you cant burn them as mp3s. if your able to fit more then 18 or so songs then you are burning it as an mp3/data disk instead of a music disk. if your computer is getting really slow i recommend you download an anti virus if you haven't already (such as avg FREE) and a spy ware malwayre removal called malwarye bites.
Apr 14, 2011 | Toshiba Computers & Internet
Need a ower manuaal for 459rog laptop
You can obtain user/owner guide manual and technical specs of your gateway in the link below.
Please leave feedback
Thanks
http://support.gateway.com/s/Manuals/Mobile/8510056.pdf
Apr 28, 2009 | Gateway 450ROG Notebook
I cant play my DVD player, on gateway
your DVD drive lens needs to be cleaned by a lens cleaner CD....try it if not worked..then your lens is faulty...
Feb 19, 2009 | Gateway ML6721 Notebook
CD drive trying to play CD when drive is empty
Apparently your laptop still thinks there is a cd to play. Be sure you closed down all your programs. I am assuming that you already logged off and shut your computer down and restarted. It could be something as simple as your sensor that detects the cd being in place and just a little dust. Use some clean compressed air that comes in a can and can be bought like at Radio Shack or electronic supply house. Put the nozzle on and blow out any dust that may be in there. Power down and then restart your computer. That should take care of your problem.
Jan 13, 2009 | Gateway 310S (2900621) PC Desktop
Gateway mt3707
the inverter or backlight is on its way out, it won't bother the operating system but you can see nothing, with most inverters its the coil that goes which is fairly inexpensive to fix, if it is the inverter, thats a lot more expensive, what you can do for time being is plug an exteral monitor into the laptop so you use it.
hope this helps
regards
Nov 04, 2008 | Gateway MT3705 Notebook
No sound device
remove the first sound device, then restart your computer, to see if vista will see that item. you may need fresh vista drivers for this to work..
Oct 23, 2008 | Gateway GT5220 PC Desktop
Gateway MT3707 Laptop external monitor hookup
i have been playing music videos. i use the fn f4 button to switch the screen. so when i switch i can see the videos on my laptop and on my plazma both. but after awhile i lose the signal and the video only appears on my laptop only. when i hit the fn f4 i can't get it on both screens. it works fine for a while then on the plazma it goes blank.
Oct 19, 2008 | Gateway MT3705 Notebook
Sound card
Hello!
here's my solution to your problem..
solution (1)
1. click right mouse button on My Computer Icon
2. navigate to Properties
3. click on Hardware Tab
4. click on Device Manager
5. if an exclamation point is present on the highlighted text then your computer have a sound card but the device driver is not installed... if this is the case, then search for the driver.
solution (2)
1. Select Start
2. Click on Control Panel
3. Click on Sound Speech and Audio Devices
4. Click on Adjust the System Volume
5. There should be 2 tick boxes
click on the lower box to display the volume icon in the taskbar..
Note:
this is only applicable if there's a sound card present or the sound card device driver is installed in your system.
If this post does not help please include the Gateway model of your pc... it is much easier to look for a driver if you can provide me with the model...
hope this post can solve your problem... :)
Aug 01, 2008 | Gateway Computers & Internet
Gateway MT3705 Notebook Logo
180 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
