Question about Achiever 260AF for Nikon TTL Flash
Can't get cap battery cover off to replace the batteries
I have slid back the battery cover so I can replace the batteries and I get it about 1/3 of the way open exposing about 3/4 of the first set of two batteries only to have the battery cover stop. It is most likely catching on the remaining two batteries that it hasn't passed over yet. I haven't looked insided of it mainly again because I can't get the battery cover off, but I'm guessing there is too much upward pressure on the batteries and they are in the way of the battery cover coming off.
Any solutions?
How to replace the remote battery
There is usually a nitch along the rim of the remote. Use a small flathead screwdriver to gentally pry open the case. If there is no nitch on the rim then try slidding one of the top covers with just slight pressure. Vuala can now replace the battery.
Apr 18, 2013 | Electronics - Others
Leuplod rx111 rangefinder
This problem is caused by the 'step' inside the battery cover which prohibits the tip of the battery from contacting the nipple inside the cover. I fitted a thin piece of aluminium strip (20thou) and the rangefinder now works perfectly. Most brands of CR2 battery now have higher sides which shield the tip - bad design.
Sep 03, 2012 | Leupold RX-III Rangefinder
How do i get the actual cover off the remote to replace the batteries. i know i need to slide down the cover but how do you actually get to the batteris
The TECO-type remote has a slide down front 1/2 cover that when slid down reveals more controls/adjustment buttons - keep pulling that cover down it will come off and reveal the slot for the batteries. Eureka!
Aug 22, 2011 | Heating & Cooling
How do you replace the battery in a Magellan Roadmate 1200
there are four hidden screws under the little rubber plugs on the back (unless they are missing) remove those screws, then use your finger nail (thats what i use) to slid it around the seem of the front and back cover to un snap the locks.
carefully seperate them and disconnect the wires off the rear cover thats attached to the board...its pretty easy...just dont be in a hurry
youll see the battery right away and its a simple remove and replace...no soldering or any other nonsense
bill
Apr 19, 2010 | Magellan Roadmate 1200 Car GPS Receiver
When cam is on? cell says plz open slide
The switch that detects when the slid is open isnt making contact, open it (remove the battery cover) and clen the 2 brass contacts, if that doesnt work, replace the back cover.
Oct 27, 2009 | Nokia N72 Cellular Phone
How to program 9242 remote to work with my Bell
The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
Oct 13, 2009 | Bell Televison & Video
Can't open battery compartment.
ashe 1977
there are two ways to fix this.
1- remove the bottom cover, take the rubber seal off from the battery compartment, remove the battery then soak the bottom cover in vinegar overnite. this will remove all corrosion. remove the battery cap and clean the threads. completely dry the cap and bottom cover, apply WD40 to battery cover threads. clean battery contact with pencil eraser ( carefully ). reinstall the rubber seal, replace bottom cover.------ best fix.
2- this may not work but it's worth a try. just apply ( carefully ) WD40 around battery cap and let it set for about an hour, re-apply and wait another half hour. If this doesn't work refer to # 1
Jan 04, 2009 | Pentax K1000 35mm SLR Camera
Stupid problem
the back cover slids off and the battery pops out
(on the NS-DV4G)
the BIG lithium ion battery is the only user servicible battery
the little watch battery is not
Jul 29, 2008 | Insignia NS-DV2G MP3 Player
Old jvc gr-dv1u battery lid cover came off
I would reccomend using the rubber glue to glue it back on. Also if you need a new battery, you can go to www.needbattery.com They have your battery listed here: http://www.needbattery.com/Camcorders/JVC/GR-DV1U.html
Their batteries are guaranteed for a year and they are 1 of the cheapest stores for batteries you will find on the net or off the net.
Mar 18, 2008 | Cameras
Achiever 260AF for Nikon TTL Flash Logo
51 people viewed this question
Top Achiever Cameras Experts
Marvin
Marvin
Are you an Achiever Camera Expert? Answer questions, earn points and help others
