Question about Kodak EasyShare Z612 Digital Camera
Error message - Memory card requires formating
Z712 IS - Frequently when the camera is power up, a screen mesage appears - "memory card requires formatting". I shut down -pull out the 4gb 'pq1' card, use internal memory until I download pics on the card -re insert and reformat. This has occured at least three times - The camera is approx 4 Mo old.
    Guru:
  • 40 Answers
It seems your card has problem. Try CMD command on computer to repair it.
Posted on Jan 09, 2018
    Passionate:
    Visited the website for 10 consecutive days.
  • 126 Answers
Before suspecting the camera, I'd simply try another memory card in it. Memory cards can and do fail and often can behave inconsistently before they fail completely.
  • 39 Answers
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
Posted on Nov 28, 2008
SOURCE: new memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Posted on Mar 28, 2009
  • 942 Answers
SOURCE: Memory Card
Hi...
The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
Good luck !!!
Regards
PCmania
Posted on Jul 06, 2009
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Posted on Oct 25, 2009
leepania
  • 1099 Answers
SOURCE: We insert a memory chip into our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Posted on Jan 04, 2010
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
How to remove card error in fujifilm jz300 camera
Welcome to FixYa.
The reasons why do you get a message "CARD ERROR" are:
1. The memory card is not formatted.
2. The memory card requires cleaning or memory card is damaged
3. Incompatible memory card.
4. Camera malfunction.
What do you need to do are:
1. Format the memory card.
2. Clean the contacts with soft and dry cloth. If the message is repeated, format the memory card again. If the message persists, replace the memory card.
3. Use compatible memory card.
4. Contact FujiFilm dealer.
Feel free to send us your comments and suggestion fi this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | FUJIFILM FinePix JZ300 Digital Camera
Hi, I have a Kodak EasyShere canera, model # Z712 IS. I used to be able to take hundreds of pictures before the memory was full on this camera. Now it says it's full after 14! How do I correct this...
Somehow, you started using the camera's internal memory which is very small. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Mar 23, 2011 | Kodak EasyShare Z712 Digital Camera
Card error
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual:
http://support.casio.com/pdf/001/EXZ60_e.pdf
Apr 28, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Changing memory cards
I WOULD PROBABLY SAY YOU HAVE A COMPATIBILITY PROBLEM BETWEEN THE POLAROID SD CARD AN YOUR KODAK CAMERA AND THAT IS WHY IT IS NOT FORMATTING. GO ONLINE TO EITHERS SITE AND ASK TO SEE IF THEY ARE COMPATIBLE. THIS MAY SOLVE YOUR PROBLEM.
Oct 30, 2008 | Kodak EasyShare C613 Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
"Internal memory requires formatting."
This error message indicates that the internal memory in the camera requires formatting or is corrupt. You must format the internal memory. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a memory card during formatting may damage the card. (Formatting internal memory also erases email addresses and album names. To restore addresses and albums, see Kodak EasyShare software Help.)
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Memory card requires formatting"
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
The camera screen displays error message
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
154 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Parshiv Luthra
Are you a Kodak Camera Expert? Answer questions, earn points and help others
