My washing machine starts out fine, but when it gets to the point when water should be removed, it doesnt. So basically, it's only washing once and everything remains soapy and the machine doesnt work any further. A technician came already, cleaned the filter, which had a bit of debris, but the washing machine never worked properly again. I checked the filter again, but it's clean. What could be the problem?? thanks alot!
check no kink in drain hose and if plumbed in unbder sink, check spigot into sink drain is not blocked. put drain hose lower down band check there is water coming out freely. if not, then suspect something trapped in hose from tub to pump
Was this helpful?
Yes
No
Popular Solutions for AEG Lavamat 72640 Front Load
My OKO Lavamat 61300 has stopped rotating (and spinning). Fills and drains OK and seems to step...
(More)
My OKO Lavamat 61300 has stopped rotating (and spinning). Fills and drains OK and seems to step through programme OK - just doesn't turn.. Is there a fuse I can check? Is it likely to be the motor itself? or could it be the starting capacitor? how can I check? thanks
The Machine runs the clean water from underneath. The pipe connection is good. (AEG Lavamat 72640...
(More)
The Machine runs the clean water from underneath. The pipe connection is good. (AEG Lavamat 72640 Update Front Load Washer)
beko washing machine not takin fabric softener, still left in the drawer at end of cycle? cleaned...
(More)
beko washing machine not takin fabric softener, still left in the drawer at end of cycle? cleaned out the drawer and washing machine using proper washing machine cleaner still not luck.
