Question about AudioBahn A4401Q Car Audio Amplifier
Will this amp push my speakers
I have two 6.5 door speakers(480 watts each) and two 6x9 speakers(800 watts each). My friend wants to sell me his audiobahn a4401q amp. I'm not too familar with this amplifier. How many watts does it have and would it be able to push my speakers?
  • 62 Answers
Whoa, I do belive your rating for your speakers are inflated. I have never heard of a 6X9 accepting 800 watts thats just rediculas, its more than my 12" sub needs. Anyways, if this amp is anywhere from 300 to 500 RMS watts you will be fine. Because the speakers are small they need very little wattage to reach there potential, usually less than 100 Watts each, and probably around 50. If you think about it most decks put out 50Watts max for each channel, because that is the max you can assume that the RMS wattage of the unit is only around 20-25 Watts of power per speaker.
Posted on Mar 25, 2007
I have aiwa nsx-kt9 speakers.kindly tell me how much watt amplifier will be right for these speakers
These speakers are 6 OHMS, that means you can only use an amp that is rated for 6 ohms. The original amp put out 20 watts (rms). Any amp rated above 25 watts per channel could do serious damage to the speakers if turned up to the highest levels.
Apr 07, 2017 | Aiwa Audio Players & Recorders
I'm new to the Car Audio seen.I just bought four 6x9's.Now I need a good Amp to push all four of them.Here's what I have.Sony XS-R6945 4 Way 6x9" 800 watt Full Range Car Stereo Speakers Power...
Look for a 4-channel amp that pushes 50 watts RMS @ 4 ohm.
Make sure the amp is CEA-2006 compliant.
Ignore peak or max watts as these are arbitrary numbers.
More info here - sparky3489.webs.com
Jan 24, 2015 | Car Audio & Video
What would be the best amp for the money to push 4 pioneer 6.5 i door spea kers n in my truck? they are pioneer ts-a1674r. 6.5 '..3-way 300W max and 35W nominal.
i would get me a 400 watt pioneer amp that ran the same ohms as my speakers maybe a 500 watt to much power on 6.5 will pop them dont ever goby max power its to much for them
Mar 04, 2013 | Jl Audio 13W7 Car Subwoofer
HIFONIC 1500D WATTS (2)2OHM L7s WAS TOLD CAN ONLY WIRE TO 350 WATTS EACH SPEAKER BEST BUY SAYS I NEED A NEW 1500 WATT KICKER AMP TO GET FULL POWER 1500 WATTS OR (2) 4 OHM L7S TO GET FULL 1 OHM 1500 WATTS
Look, if the amp is 1500watts mono, then you have the capability to run a sub up to the full 1500watts, but i see on the specs for this amp that it has output for 2 speakers, which means up to 750watts each speaker. That's more than enough to power your L7's. They're trying to sell you something you don't really need in my opinion. Hope this helps.
Jul 12, 2011 | Car Audio & Video
I have a ca260 car amplifier, and wanted to know if it 1ohm stable
it is .5 ohm stable but will heat up in .5 ohm so make shure there is lots of ventilation at 1 ohm it will not heat up very much but will still need venting they really kick and control the speaker very well (no or little distortion ) even in low ohms you will need lots of current for them in single channel mode at 4 ohm its 120w 2 ohm its 240 and 1 ohm its 480 and .5 its just under a kilo watt at .5 you will need 40amps of current i have 6 of these amps as a system and i am upgrading to mcintosh amps as there are few amps better than the hk ca 260s you will love this amp
Sep 14, 2010 | Harman Kardon Car Audio & Video
I have a behringer 1500 watts amp that is clipping
What is happening is that your amp can deliver 1500 Watts at a given impedance. The Sub PROBABLY is a higher impedance. Your amp runs out of voltage due to the speaker impedance, hence it "flat tops" or clips.
You will probably find the sub is 8 ohms and your amp might deliver 1500 Watts on a 2 ohm system (this is "specsmanship" to sell their product... more is better thing...
If your amp was as above, the max voltage output would be the same before clipping but with the resistance 4 times, the current is only one fourth that which would deliver 1500 Watts. So you would only get 1500/4 Watts into the speaker or about 375 Watts.
Mar 10, 2010 | JBL SP5 Main / Stereo Speaker
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Can a rf 201s amp push 4-6x9s and 4-104s door speakers
Hello jon_jonmay,
Wiring 4 speakers to each of 2 channels, you will need to wire them series-parallel and run them at 4 ohms. If you wire all 4 parallel, the load will be 1 ohm and the amp is only stable down to 2 ohms.
According to your manual, the 201s will deliver 50 watts into each channel at 4 ohms . So it will be supplying about 12.5 watts per speaker which is about what you get with the average factory radio. They will work OK, but they're not going to be very loud.
Hope this helps.
Apr 21, 2009 | Rockford Fosgate Punch 201S Car Audio...
High distortion
The head unit may be rated at 200 watts but it cannot produce more than ~20 watts of real power per channel. There's no way that it can drive the high end speakers to a level that will be needed to compete with the subs on a 1000 watt amplifier.
Apr 18, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
1000 watt amp sony xplod
That's not a 1000w amp. It's a 400 watt amp when loaded to it's lowest rated load. If you have one speaker per channel (the only safe load if you have single 4 ohm coil speakers), you're only getting 165 watts/speaker. It's probably distorted because you're driving it to clipping.
Jan 01, 2008 | Car Audio & Video
AudioBahn A4401Q Car Audio Amplifier Logo
165 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
