Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I have a new Epson stylus sx 105, can i connect to this via a LAN port on a wireless router and print from anywhere at home? cheers lloyd.
  • lloyd_loft Dec 17, 2008
    cheers Nic61 thats what happens when you let the missus out to buy a printer lol
  • no27a Jan 15, 2009
    We have the exact same printer "epson Stylus Sx 105" but it refuses to print and makes a loud clicking noisey sound!
  • Epson Master
  • 1,879 Answers
Option:
first connect the printer via USB and install the printer software to your computer.
next, disconnect the printer from the computer and delete the printer ICON from Printers & Faxes (will only remove the icon and not the driver).
get a printer server with USB port for the printer and Ethernet for router connection.
connect the printer to the printer server via USB then the printer server connects to your wireless router via Ethernet.
Use add a new printer wizard and search for printer on the network.
Posted on Jan 17, 2009
    President:
  • 1,073 Answers
Nop, sorry to say M8, that model isent supporting networking
Here is the spec for that printer
http://www.epson.co.uk/printers/durabrite_general_printers/Epson-Stylus-SX105-printer.htm
Good luck to you
Posted on Dec 17, 2008
  • Nicolas
    Nicolas Dec 17, 2008
    Cheers M8!:) lol ..and good luck 2 you!:)
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Tip
Setting up Epson Stylus SX515w on a PC.
0 false 18 pt 18 pt 0 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-ansi-language:EN-US;} This guide will show you how to setup the Epson Stylus SX515w, without using the setup CD & USB cable.
1) Using the Control Panel on the printer, press the Spanner/Screw driver button.
2) Scroll though the menu until you see Network Settings & press ok.
3) In the following menu select Wireless LAN Setup.
4) Then select Advanced Setup.
5) Then select manual Setup & press ok.
6) This guide assumes you are connecting through a router via Wi-Fi, in which case you will need to select Infrastructure Mode and then press OK.
7) Select Search SSID & this will search for your wireless network.
8) If your wireless network is showing, make sure it is highlighted then press OK.
9) Now you will need to enter the encryption type, this will depend on the length of the wireless key. WEP 64 Hex (10), WEP 64 Alpha (5), WEP 128 Hex (26), WEP 128 Alpha (13). Any router that has 8 characters I would normally recommend selecting WPA PSK TKIP UNLESS you know that the key is WPA PSK AES.
10) Now you will need to input the security key depending on which type you have, as advised above.
11) Once the key is in correctly you need to press OK. You will then see a Confirm Settings screen. Press OK on this screen and YOU MUST WAIT 30 SECONDS for the printer to establish a wireless connection with the router. After the 30 seconds please go down to Confirm Settings and press OK. This will tell you if it has successfully connected to the router. At this stage you need to make a note of the IP address. This normally starts 192.168.x.x
12) On the PC the printer will need to be installed, I recommend downloading the driver from here:
13) Once installed go to Start > Control Panel> Printers (This will vary slightly depending you version of Windows).
Right click on the printer, select properties (Printer properties for Win 7). Select the ports tab and add a new port.
When adding a new port select Standard TCP/IP, then click add new port.
NB The Standard TCP/IP port is recommended when assigning static IP address to the printer. (See router documentation on assigning static IP address).
If using a dynamic IP Address I would recommend downloading and installing the Epson net printer port. You can use a Standard TCP/IP port, however when the IP address changes communication between the printer and PC will be lost.
Setting up both port types are the same, once you select add port you will need to enter the IP Address, which we noted down previously from the printer. Once entered keep clicking next, then finish.
You should now be able to print over the network. To use the scanner over the network you will need to open Epson scan settings, (a separate utility to Epson scan) this will need to be set to network and contain the same IP address noted down earlier for the printer.
If you still have issues check your firewall and router settings, i.e. mac filtering etc.
on Dec 11, 2009 | Office Equipment & Supplies
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
Can't print to a Epson STYLUS SX510W from MacBook Pro OS 10.5 via wifi
First make sure the Wifi light on the printer is lit which will show if the printer is connected wirelessly to the router or not. If not then enter the Network settings on the printer and carry out a Wireless Lan set up using the wizard.If there is now a light Go to Apple Menu > system Preferences > print and fax, Delete the printer that is in the list and then select Add. Select Bonjour and wait for the printer to appear, highlight it and then add it.
Jan 13, 2010 | Epson Office Equipment & Supplies
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Jan 14, 2009 | Epson Stylus CX9400 Photo Printer
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
379 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
