Question about Garden
Adjusting a Craftsman Snowblower Carburetor
I just purchased a Craftsman 179cc 24" Snow Thrower brand new. Is there an adjustment on the carb to adjust the speed/rpm? Even with the throttle at the high or fast position, the motor just seems to lag. Adjusting the choke on this unit doesn't seem to make any difference, aside from when the unit is cold. It just feels as though an adjustment would rev the engine to its proper rpm. I'm just not sure if there is an adjustment screw. I read somewhere that some engines don't have an adjustment, and it is what it is. I have the manual, and in the troubleshooting section, it says "If the engine runs erratically, the carburetor is not adjusted properly". Then it says, "Contact your Sears Parts & Repair Center".  Go figure!
Help!
  • rlemer Dec 22, 2008
    I have the exact same problem. There must be a carburetor adjustment.
Crafsman snow blower have choke on to run it
Posted on Oct 30, 2009
Bring it back to Sears they have a life time warrinte
Posted on Dec 22, 2008
Where are the adjusting screws on the carburetor for the st330p snowblower and what is the procedure to adjust both idling speed and full speed to prevent stalling under load.
Your carburetor is not adjustable. If your engine does not operate properly due to suspected carburetor problems, take your snow thrower to a service center/department.
http://www.husqvarna.com/ddocdownload/HUSO%2FHUSO2014_AAen%2FHUSO2014_AAen_ST330P_115683027R1.pdf
Feb 20, 2017 | Garden
Snow keeps getting stuck & doesn't shoot out, even if the snow isn't heavy, after several
View Comment - MovingSnow.com
movingsnow.com/.../craftsman-88395-30?-277-cc-two-stage-snow-blow...
Oct 14, 2015 - 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer at $1049 (minus ... If you do get something stuck in the front end - yes it will slip the belt.
Cheap 2 stage Snow Blowers - There are a few good ones ...
movingsnow.com > ... > 24 in Craftsman 88172 179 cc
Nov 7, 2014 - Sears carries other brands besides Craftsman but they are all not as good of ... Briggs and Stratton 1696610 Dual-Stage Snow Thrower with 208cc ...Subscribe to our mailing list and get interesting stuff and updates to your email inbox...... up to the 28 inch 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer.
Dec 29, 2015 | Craftsman 28 In 277cc* Dual-Stage...
Does 4-stroke and 4-cycle mean the same thing?
yes ... intake, compression, power, exhaust .... vs 2 cycle which mixes them down to two.
Mar 30, 2015 | MTD PRODUCTS INC Craftsman 21" 179cc*...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snow blower dying out?
Its the carburetor. Needs to be cleaned. But try this first. On the bottom of carb is a round bowl with a bolt holding it on .If snowblower has gas in it clamp fuel line to stop fuel leakage. Remove bolt and pull bowl down slowly. Look in bowl to see if there is water at bottom under gas.To be sure dump out fuel and clean out bowl with clean rag and some air. Next place a small piece of tube in bottom of carb that you took bolt out to hold bowl on. Blow air in to remove any dirt and reassemble carefully and refuel carb and start engine. Good luck.
Feb 17, 2014 | Craftsman 21" 179cc* Single Stage...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Runs for 10 minutes and stops
When running is the idle smooth or up and down?
Is the chock operating, or adjusted after the motor gets warm?
Is the carburetor needle adjusted after the engine idles to warm as it should be to be set correctly.
Are you blowing snow when it dies or at idle?
Feb 01, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Carberater for my snow thrower isn't getting gas
The carburetor could be clogged. Try spraying some carb cleaner into the engine to see if it starts. If it does, then some part of the carb may have varnish clogging some of the ports.
Jan 30, 2014 | Craftsman 24" 208cc Dual-Stage Snow...
Craftsman snowblower
does it have a fuel shut off valve on it , make sure the tank hose to carb is clear ,take the carb bowl off to see if the float and needle and seat are not sticking
Jan 22, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Garden Logo
4,924 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
