Question about GE 2-9450B Corded Phone
Hi We had a power outage last night. We can't remember how to re-set the GE ProSeries Multi-Line Telephone Model 2-9450.
5 Suggested Answers
  • 97 Answers
SOURCE: Ring Tone
if you want to make it silent hold down the hash key. ifnot then you may have to turn the volume of the ringtone down to 0.
Posted on Jul 15, 2008
SOURCE: GE PROSERIES SPEAKER PHONE MODEL GE 2-9438B
I found the mini-reference book to my GE ProSeries 2-9436/2-9438 under the number log on my phone. I scanned the pages into a PDF file. I'll be happy to send you a copy of the PDF file.
Posted on Feb 26, 2009
  • 3 Answers
SOURCE: GE 2-9450 CORDED PHONE PROBLEM
I bet the problem is that you used to have two phone lines and now you only have one line. You cannot program an extension into one of these phones unless both Line1 and Line2 coming into the phone are working- it will act as if the extension you picked is in use, but the actual thing it is complaining about is that Line2 isn't working. The phones might have been working for years on a single phone line as long as they didn't lose power. But you don't have to throw the phones away just because you gave up your second phone line, you can still make them work. (I did it for a 12 phone system.) The way to to it: make a special cable that connects your single incoming phone line to both L1 and L2 on the phone, tricking the phone into thinking both L1 and L2 are working. Then program the extensions into the phones, and go back to using a normal cable so that only Line1 is hooked up. To make this cable: take a normal male to male cable and cut off one end. Then connect both the black and the green wires of the cable to the green post in a standard phone jack (the kind you would surface mount on the wall will work best), and connect both the yellow and red wires to the rec post inside the phone jack. Now plug your incoming phone wire into the phone jack, and plug the wire you connected into the jack into the back of your phone. The phone is probably already blinking red on the intercom, just push the extension number you want it to have, making sure there are no conflicting extensions already in use.
I would reconnect the phone using a normal line so that only Line 1 is "hot", don't leave it on this double-connected cable any longer than you need to in order to program the extension.
Posted on Dec 31, 2010
  • 102366 Answers
SOURCE: I am looking for a telephone manual for my GE Telephone
http://www.home-electronics.net/USER-GUIDES/29586_DOM_EN_CD_IB.pdf
Posted on Jun 06, 2011
Me harddrive is not on anymore, i left it on last night?
There was probably a power outage and you didn't notice it because you were asleep. The Computer's hard drive does not turn on by itself after a power outage.
Aug 02, 2011 | Computers & Internet
After power outage, does not print confirmation report after faxing
I hope your fax is on a "surge Protector" providing protection for both Hydro and telephone line.
Use your operators manual to check setting of Confirmation Report as it can be set to OFF/ON. Proceedure varys by Manufacturer and model.
May 19, 2010 | Office Equipment & Supplies
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
My coffee pot died during the night
It had nothing to do with the coffee pot. I blew a breaker!
Aug 30, 2009 | GE Coffee Makers & Espresso Machines
Ring Tone
Jul 15, 2008 | GE 2-9438C Corded Phone
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
Phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
Nov 19, 2007 | Samsung Prostar 816 Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Lands Phones Logo
35 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
